Forums >> Revit Building >> Technical Support >> Display Shifts
Tue, Apr 5, 2005 at 5:04:14 PM | Display Shifts
fkremkus
I made a piece of wall geometry that was manipulated with the edit profile command from the option bar to an arc. Once I try to add another wall joining at the corner to first wall the geometry will shift and the arc will be at a skew. I reinstalled the software and tried multiple ways to construct the walls. Please advice. Thanks in advance, Fabian
Tue, Apr 5, 2005 at 6:29:27 PM | RE: Display Shifts
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Place the walls first with the join, then edit profile. Or can't you just fix the profile after you've joined the wall and the arc has gone askew? Agree it shouldn't happen, but shouldn't take much to fix?
Display shifting in Context tab
Thu, Nov 12, 2009 at 7:21:26 AM
Pattern - Running Bond
Tue, Dec 1, 2015 at 2:29:45 PM
Imported Text Boxes from AutoCAD to Revit 2011 New Line Shifts Text Upward
Wed, Dec 29, 2010 at 5:27:08 PM
text box
Tue, Jan 6, 2009 at 4:57:33 PM
Room Separation Lines won't display [ 1 2 ]
Mon, Feb 19, 2018 at 2:00:11 PM
15
Page generation time: 1.1485
