Forums >> Revit Building >> Technical Support >> Door schedule manipulation...
Thu, Jun 5, 2008 at 6:34:32 PM | Door schedule manipulation...
raredmon
Is there any way to make a door not show up in the schedule? Sometimes I do not want every door in my project to appear in the schedule, for instance if a door is existing it would not be necessary for it to be in the schedule.  Please help if you know.
 RRR
Revit 2008
Fri, Jun 6, 2008 at 1:00:29 AM | Door schedule manipulation...
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Well it is possible to filter a schedule... A schedule is also based on a current phase.  Meaning you could just adjust your phase filter to only show new...
Regards,
Chris.
Sun, Jul 20, 2008 at 11:10:18 AM | Door schedule manipulation...
3ab8ari
Revit shows the "Shear wall openings" as doors in the door schedule . I am trying to filter them out.....
In the door schedule, I am not able to filter by Type or Family:Type, which I think is the reason of the problem you are having as well. Anyone have any ideas on how to go around this ? (other than adding another parameter that users have to manually fill ?)
Mon, Jul 21, 2008 at 8:09:51 AM | Door schedule manipulation...
3ab8ari,  The reason you can't filter the door/opening type is that you have not included it in your schedule.  Include it, then filter out what you dont' want and hide the column.
Mon, Jul 21, 2008 at 1:48:10 PM | Door schedule manipulation...
3ab8ari
I have included them. Could you please post a screen shot of what you mean ?
I think there is a misunderstanding between what we both mean Smile
Mon, Jul 21, 2008 at 2:22:47 PM | Door schedule manipulation...
3ab8ari,
I'm sorry, I had forgotten that the types field is not available as a filtering element.   You will need to add a mark number to your opening and filter for that.  You do not need to show the mark number on your plans.
Fri, Apr 29, 2011 at 2:30:59 PM | Door schedule manipulation...
DeifyMe
4 Stars: 2 Votes
I'm reopening this thread since I have somewhat similar question.
How do I add a parameter that could go under the 'Hardware' heading? I want to add a column for Door Sweep along with all the other hardware items? Any advice?
Mon, May 2, 2011 at 10:03:54 AM | Door schedule manipulation...
DeifyMe
4 Stars: 2 Votes
My apologies for posting this, I figured out the simple solution. I was working off an old project so I wasn't sure how the schedule was created. The parameters were all grouped and given a heading. All I had to do was ungroup them and then regroup them including the new column.
Schedule Manipulation
Mon, Jul 21, 2008 at 8:19:35 AM
Schedule material mark in door schedule - Revit 2014
Fri, Jan 19, 2018 at 2:57:03 PM
Door Schedule
Fri, Aug 17, 2012 at 7:07:50 AM
Customized Door Schedule Needs Help
Thu, Aug 25, 2011 at 5:53:09 PM
Trying to Schedule a door that lives in a Window Family
Thu, Jan 16, 2014 at 12:07:10 PM
Page generation time: 1.0879
