15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> View Range problems- seeing wall detail
I'm using Revit 2009. I am building a receptionist desk that is a essentially a counter top on a halfwall. The wall is 2'-4.5" tall. I drew a callout in plan so I could show this underneath the countertop. I set the view range under the counter top- anywhere from 1-6 to 2-0. It didn't matter, I'd always get just two lines like I am in course detail (which I am not). I can never see the sheathing or finish material. I need to see this so I can accurately detail my trim and use the edit cut profile in a certain place. I have also tried a plan region to no avail. No matter what I try, I always just see two outlines of the walls on any wall under 6 feet or so. Any help?
Actually there is an anoying little issue with short walls in Revit. No matter what you do you can't show its finishes if a wall is below a certain distance. My suggestion would be to use detail lines on the callout plan to depict the finishes. Sorry. I am hoping they decide to change this in a future release.
Actually this is only true for walls with an unconnected height. Just make sure your wall goes up to a level with an offset rather than using the unconnected option and it will show correctly.
Regards,
Chris.
" Actually this is only true for walls with an unconnected height. Just make sure your wall goes up to a level with an offset rather than using the unconnected option and it will show correctly. This did it for me. Thanks!
Edited on: Fri, Jun 6, 2008 at 8:34:43 AM
Thanks, Mr Spot I have been searching for the answer to this for a few months now. I don't usually us a constrained height on my wall so I never thought to check that. Thanks again.
REVIT 2010 - Section Cut Detail Mark & View Range |
Tue, May 4, 2010 at 11:29:34 AM
low wall not displaying correctly with view range |
Fri, Aug 3, 2012 at 4:35:37 PM
fine detail missing on duplicated wall, plan view?? |
Mon, May 1, 2006 at 8:31:20 PM
View Range Problems |
Mon, Oct 31, 2016 at 6:06:38 PM
view range |
Fri, Sep 7, 2007 at 2:28:04 AM
