28 Users Online (26 Members):
Forums >> Community >> Newbies >> Automatically Render to a new location other than internal hard drive?
I am currently using Revit 2009 on a apple computer which is partitioned to have both vista and mac os. Currently many of my renderings are too large to render to my vista partition, as I did not give it enough space when I partitioned the drives. I would like to avoid uninstalling vista and re-partitioning at the most as it willl cause a huge delay in my thesis project. Is there a way to set the settings for when Revit renders to automatically save to an external hardrive, or a different location other than my "pc". Also I was not quite sure where to find this location. Thanks so much for your help!!!
You can only control when the image is exported to, you cannot change its default rendering location...
Regards,
Chris.
I believe you can change the tmp. variable... I am testing to see if this works out. Do you if there is a way to set batch settings as in have several render at the same time, or at least one after another?
Not enough hard drive space |
Sat, Jan 8, 2011 at 6:09:16 AM
11
Local Files and Reformatting my Hard Drive |
Thu, Jun 7, 2012 at 8:24:39 AM
Render Internal Lighting Issue |
Sun, Nov 7, 2010 at 8:04:47 PM
Are solid State drives ok for Revit Architecture? |
Tue, Nov 8, 2011 at 8:10:51 PM
Pattern file location on drive |
Wed, Mar 18, 2015 at 12:26:06 PM
