Forums >> Revit Building >> Technical Support >> Doors and curtain wall
Thu, Jun 5, 2008 at 11:08:18 AM | Doors and curtain wall
bhobho
HI,
I would like to know if we can  create  doors in the curtain wall
 Revit 2008
Thanks in advance
Thu, Jun 5, 2008 at 12:38:44 PM | Doors and curtain wall
4 Stars: 205 Votes
I think today i just respond to this question but Yes, you can, just pick in panel you want to be a door, go to properties, edit, duplicate with another name (to preserve the others), "load", go to folder where you have "Curtain Wall Panels", select what do you want and done... i think it's all...
Fri, Jun 6, 2008 at 1:07:18 AM | Doors and curtain wall
bhobho
I have tried but did not succeed
I hope to find help for this problem...plz..
see attached
Fri, Jun 6, 2008 at 1:21:26 AM | Doors and curtain wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is a FAQ.  Check out my blog for my answers to similar type questions.  But you must first load a curtain wall door (they are special types of doors and are do not come in under the door option)  tab select the curtain panel,  Now hit the type selector drop down and you will see your curtain wall door in this list.  Simply select it and thats it.
Alternatively, you can tab select the panel, then go to the type selector and select a " basic wall" type.  Now you can place a standard door in this wall like normal...
Regards,
Chris.
Fri, Jun 6, 2008 at 1:54:29 AM | Doors and curtain wall
bhobho
Thank you for assistance..but I have a question
How can I get a curtain wall door ?
Please explain how ?
Thanks in advance..
Curtain wall doors
Mon, May 4, 2009 at 2:05:34 AM
Curtain wall doors wont center up
Mon, Oct 12, 2009 at 4:28:48 PM
No curtain wall doors on curtain walls!
Sun, Nov 22, 2009 at 7:10:58 PM
tagging curtain wall doors
Mon, Jul 30, 2007 at 3:14:11 PM
Storefront Curtain Wall Doors
Fri, Feb 1, 2013 at 10:51:37 AM
Page generation time: 2.2807
