Forums >> Revit Building >> Technical Support >> BUG in 2009??
Tue, Jun 3, 2008 at 2:33:22 PM | BUG in 2009??
mflure
Greetings all,
Wondering if you have run accross this issue with the 2009 version.
 I copied and upgraded my project to 2009 and a perticular thing has happened.   In my RCP I can see my HVAC registers and sprinkler heads just fine, look great.  but the issue is when it comes time to plot.  They disappear and when I export them to a ACAD file I get my sprinkler heads but my HVAC registers are still missing.  It gets even crazier.. I can look at the ACAD block list and the block is there for the HVAC... and I can see them if I place them in ACAD.. Anyone run accross this??
 Mike
Tue, Jun 3, 2008 at 6:08:30 PM | BUG in 2009??
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
It sounds like a memory issue...
What are your system specs?
Regards,
Chris.
Wed, Jun 4, 2008 at 8:17:05 AM | BUG in 2009??
mflure
Ahh Found the little pain.....
After searching a bit more found another post that was exactly the same problem that I was having.  I guess there is a little change from 2008 to 2009 with all of those old families that sneek in.
All of the Light Fixtures I have in the file worked, which was wierd.  But my HVAC register and Sprinkler Head were not.  Well I had to go in and create a opening to the family ceiling level and that made everything work fine.  So I guess I didnt have a plotting problem at all it was a display problem / bug.
I'll post the other thread as soon as I find it again.
 Thanks for the reply Mr. Spot. I actually was thinking that could be a possible problem
 Mike
Wed, Jun 4, 2008 at 8:35:19 AM | BUG in 2009??
mflure
Here is the Link to the other thread
http://www.revitcity.com/forums.php?action=viewthread&thread_id=11588
REVIT 2011 BUG OR NOT BUG?
Mon, Dec 6, 2010 at 6:28:30 PM
Glass Rendering Bug
Tue, Jun 3, 2014 at 7:40:45 AM
14
Revit 2009 Fatal Error while
Wed, May 7, 2008 at 9:38:33 PM
v.9 area analysis
Fri, Apr 21, 2006 at 6:23:33 PM
REVIT 2008 BUG (Y2008)
Tue, Jan 8, 2008 at 8:22:42 AM
Page generation time: 0.1835
