Forums >> Revit Building >> Technical Support >> Room Tags Indicating Rooms on Different Levels - Revit Architecture 2009
Tue, Jun 3, 2008 at 1:22:18 PM | Room Tags Indicating Rooms on Different Levels - Revit Architecture 2009
suedehart
suedehart Avatar
I'm working on a split level school with levels ranging from 0'-0" to 8'-0", and need to show an overall plan at 1/16" scale with room tags.  Is there a way to get Revit to recognize rooms for tagging below the cut plane?  So far I can tag levels 4'-0" and 8'-0", but the rooms at 0'-0" don't show up.
 Any advice is much appreciated!
Wed, Jun 4, 2008 at 12:09:35 PM | Room Tags Indicating Rooms on Different Levels - Revit Architecture 2009
suedehart
suedehart Avatar
OK - I think I figured it out - if I draw plan regions around each different level (View-Plan Region), I can adjust the cut planes (via element properties) accordingly and therefore tag the rooms regardless of which level they're associated with.
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:51 PM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
REVIT 15: Can not place rooms on upper and lower levels....
Tue, Feb 12, 2019 at 4:58:36 PM
Rooms & Room Tags
Tue, Nov 17, 2009 at 7:14:52 AM
Imported 2D Cad drawings > Rooms and Room tags possible?
Fri, Jul 1, 2011 at 1:07:42 PM
Page generation time: 1.5945
