Forums >> Community >> Newbies >> printing texture
Tue, Jun 3, 2008 at 11:33:01 AM | printing texture
Altor
hello guys
i am new with revit and i was hoping someone could save me some headache.
i have this culutred stone texture on my walls and their material is set in the "surface pattern" to look like cultured stone. Everything seems to look fine on the view and on the sheet but when i try to print it some of the walls have the right texture and some just go all matrix on me. i made sure that there are no two walls overlapping eachother at those points and also i check the properties of a well printed wall vs a non well printed and they seem to be identical. i tried printing it on pdf and i get the same results. i attached a jpg of it. hopefully you guys can solve my problem.
i appreciate any advice or a guess.thx
AT
Tue, Jun 3, 2008 at 1:11:01 PM | printing texture
4 Stars: 205 Votes
Hi ALTOR, can you put here the model to see what a hell is going on?
Tue, Jun 3, 2008 at 1:49:44 PM | printing texture
iliansky2002
Hi,
 Try to look at the properties of the external cladding of the wall  (Under structure)-the surface pattern hatch.
Look also on your plan drawings if you don't have any other walls that enter the facade one.
 Regards
Wed, Jun 4, 2008 at 3:25:50 PM | printing texture
Altor
for some reason all the sudden it changed and all the walls got the right textue. and i didnt do anything to it. really weird. i am starting to think that revit is abit buggy sometimes. you can do the same thing twice and get two different results.
Texture fix
Mon, Jul 9, 2012 at 1:25:13 AM
Roof texture problem.
Tue, Jan 7, 2014 at 10:05:07 AM
Texture Mapping at the Corner
Mon, Sep 17, 2012 at 11:21:51 AM
Texture Map Problems
Sun, Feb 25, 2007 at 7:56:31 PM
Texture behaviour with new family from imported 3D object
Tue, Sep 27, 2016 at 6:58:11 AM
11
Page generation time: 3.6064
