Forums >> Revit Building >> Technical Support >> openings at angles
Tue, Apr 5, 2005 at 1:16:10 AM | openings at angles
ridhs
im trying to do corbusier's ronchomp type openings in my wall.. wat do u suggest is the best way???
Tue, Apr 5, 2005 at 9:02:14 AM | RE: openings at angles
arnosandoval
5 Stars: 3 Votes
I would recommend using sweeps or blends for the openings; using the void tool. If you create an in place opening familiy, then the void will act like an opening. Hope this helps.
Embedded Angles won't chamfer
Tue, Apr 17, 2012 at 8:23:58 AM
How do you create diagonal openings in walls (as viewed in plan view)
Mon, Jun 13, 2016 at 11:22:13 AM
Corner angles
Sun, Apr 5, 2009 at 5:35:32 AM
Copy Monitor Shaft Openings
Thu, Oct 21, 2010 at 8:16:14 PM
Curved wall openings
Fri, Oct 15, 2010 at 12:42:11 AM
Page generation time: 0.0739
