Forums >> Revit Building >> Technical Support >> ceiling tag for mass created clg.
Mon, Jun 2, 2008 at 11:40:48 AM | ceiling tag for mass created clg.
tonyL
problem :
i have created a custom ceiling w/massing.
i have managed to tag the ceiling.
 however the tag has a ceiling title eg. CEILING 5
and has a A.A.F. at the end of next line. when i tried to click the second line and enter the ceiling height and matter of fact i had entered the height it doesnt show on the tag.
the same tag when applied to ceiling provided by revit has no problem displaying the ceiling height.
what is going on and why?
please advice. thanks.
Mon, Jun 2, 2008 at 12:38:04 PM | ceiling tag for mass created clg.
rkitect
rkitect Avatar
4 Stars: 29 Votes
When you say you've created a custom ceiling; did you create it as an in place family and set it in the Ceiling category?
Regarding the ceiling name, you will need to rename it using the project browser.  You'll find it under Families > Ceilings > Ceilnig 5 > Ceiling 5.  Rename the last item there to get the ceiling tag to reflec tthe correct name.
For the height, because the ceiling is a custom object, it has no clue how to treat the "Height Offset from Level' parameter.  More importantly, you'll notice that the ceiling has no "Height Offset from Level" parameter.  This is because it is an in place creation.  Instead, your ceiling has an "Elevation" parameter... now why Revit doesn't allow you to tag an object's elevation (or at least it's not an option when creating custom tags) is beyond me.  To be honest, the simplest way to do this would be to use shared parameters.  i just tested it out and it took me about 5 minutes to set up the parameter and make the tag work.  Th problem here is that the shared elevation parameter WILL NOT control the height of the ceiling.  So if you need to change the height of the ceiling, you'll have to manually change the parameter in the tag.
Hope this gets you started, I'd love to hear from anyone that can get an elevation or Height Offset tag working with in place ceiling families.
Ceiling Tag associate to Center of Ceiling instead of Perimeter.
Mon, Feb 8, 2016 at 12:46:31 PM
Leader Line Origin in Ceiling Tag
Tue, Jun 28, 2011 at 7:28:12 AM
filter ceiling tag heights
Wed, Sep 15, 2010 at 4:04:17 PM
Room Tag With Ceiling Offset from level, or Ceiling High
Sun, Mar 8, 2009 at 11:03:00 PM
floor height tag in reflected ceiling plan (2015)
Fri, Mar 12, 2021 at 3:49:52 PM
14
Page generation time: 0.5489
