Forums >> Revit Building >> Technical Support >> dimensions
Mon, Jun 2, 2008 at 10:48:25 AM | dimensions
fifthtexas
hi
using revit 2008, everytime i am dimensioning door and window placements i modify say first window from wall say 6ft, second window 8ft from first window, but everytime i do this the first dimension changes back from 6ft to original placement and vice versa. why is this happenig. can not seem to control my dimensions. also when i use my witness lines. i want from edge of building set it say 6ft from end of building but when i go back to it later it has gone back to wall centre line. any help please
regards
fifthtexas
england
Mon, Jun 2, 2008 at 11:04:11 AM | dimensions
rkitect
rkitect Avatar
4 Stars: 29 Votes
fifthtexas,
 I know this is a rudimentary question, but are you selecting the second window before changing the dimension to 8'?  When you change a dimension, it is going to move the object that is selected.  Sometimes people forget to select the object that they want to move.
When you change the witness line are you using the temporary dimensioning lines or a dimension object that you placed?  The difference is when you select an object, Revit displays dimensions called temporary dimensions.  Temporary dimensions disappear when you deslect the object.  A Dimension object is a dimensions annotation object the you place and is permannent.  Dimension objects do not disappear when you deselect an object.
Mon, Jun 2, 2008 at 12:45:29 PM | dimensions
fifthtexas
thanks for quick reply
yes using temporary dimensions noticing this on everthing so i am doing something wrong.
example
place first window on level 1 wall in not exact position place second window further along. come out of window command. i then go to dimension where i want these windows placed. select first window modify dimension 6ft from edge of wall, then modify next window change dimension to 8ft from first window (centre to centre).
second window changes ok, but then first window does not stay at 6ft changes back and vice versa. they wont be placed where i want them for some reason. seems to be a confict somewhere, from a internal wall along as this dimension also shows. any idea where i am going wrong
thanks for your help
regards
fifthtexas
Mon, Jun 2, 2008 at 1:56:21 PM | dimensions
It sounds like you have two windows with a dimension from the wall to the first then to the second.  If so, don't adjust the placement of your second window using the dimension string, use the temporary dimension - not the blue permanent dimension.   REVIT assumes you are trying to adjust the placement of the first window.  That is why both dimensions in your string are blue.  You could also edit your orginal dimension string to get a reference point on the other side of your last window.  Now when you select the window the correct two dimensions will turn blue.
If available, everything in REVIT assumes dimensions in two directions.  Adjust one side and both dimensions change but the overall distance from the two extreme references will not.
Mon, Jun 2, 2008 at 3:21:30 PM | dimensions
rkitect
rkitect Avatar
4 Stars: 29 Votes
He should be able to use the dimensions string to change the dimension of the second window (assuming the dimensions string is witnessed to the window).  He would just need to make sure he selects the second window BEFORE changing the length.  When you use the blue dimension text to change the length of an object, it only applies to the object(s) that are selected.  I have a video I'm trying to get uploaded, I'll post it when my computer begins cooperating with me again.
Edited on: Mon, Jun 2, 2008 at 3:31:23 PM
Mon, Jun 2, 2008 at 5:18:00 PM | dimensions
mhans
3 Stars: 10 Votes
Pin the first window and try to adjust the dim of the second window. Lock the dimension between the first and the second window so they translate as one.
Motto: "No Post left behind"
Mon, Jun 2, 2008 at 5:53:28 PM | dimensions
Pins and locks do work but too many of them will result in many problems in the future.  If you learn to use the REVIT tools that are there, you can reserve the pins and locks for the important areas.
The temporary dimensions are great! - Learn to use them.
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:08 PM
Changing Dimensions
Mon, Feb 7, 2011 at 9:02:52 AM
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:56 PM
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:51 AM
Page generation time: 0.0889
