Forums >> Revit Building >> Technical Support >> Drawing Reference Planes in 3 Dimensions?
Mon, Jun 2, 2008 at 9:09:18 AM | Drawing Reference Planes in 3 Dimensions?
FreemanAndMajor
Revit 2008, I am trying to draw a reference plane in a family for the purpose of a sweep. But the RP needs to be at an angle to the x grid and at an angle to the z grid. Any suggestions????
Mon, Jun 2, 2008 at 9:14:12 AM | Drawing Reference Planes in 3 Dimensions?
Dafpfy
3.5 Stars: 11 Votes
try placing in one view and then , change to other view , select previous , and rotate
but if its to make a sweep you will might want to to this with a line
Edited on: Mon, Jun 2, 2008 at 9:15:42 AM
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Mon, Jun 2, 2008 at 9:26:10 AM | Drawing Reference Planes in 3 Dimensions?
FreemanAndMajor
No I have tryed this and it will only allow me to rotate this in one directions. Any other suggestions????
Mon, Jun 2, 2008 at 9:38:42 AM | Drawing Reference Planes in 3 Dimensions?
Dafpfy
3.5 Stars: 11 Votes
it worked for me in a generic model familie,,
i drew the RP in planview , named it, and then rotated it in front view
peace is the path."
Mahatma Gandhi.
Mon, Jun 2, 2008 at 10:14:37 AM | Drawing Reference Planes in 3 Dimensions?
FreemanAndMajor
If i had the origional line drawn down the x axis. I need it rotated in the y dimension , then roated in the z dimensions and then tilted in the x dimension.... Any suggestions????
Mon, Jun 2, 2008 at 10:33:49 AM | Drawing Reference Planes in 3 Dimensions?
4 Stars: 205 Votes
Hi, use "Reference Lines" to do it, and use the Work plane of that Reference line to rotate in the axis you want...
Mon, Jun 2, 2008 at 10:51:35 AM | Drawing Reference Planes in 3 Dimensions?
FreemanAndMajor
Dafpfy, I opened your model and saw that is was done, when i went and drew reference lines in 3D view it was on a new work plane, but i wasn't able from any view to see where that work plane was drawn or understood how it was created. I still can not get a reference plane or line to rotate in any but one axis... any suggestions.
Mon, Jun 2, 2008 at 11:00:59 AM | Drawing Reference Planes in 3 Dimensions?
lunchtrayrider
3.5 Stars: 7 Votes
two reference lines
Mon, Jun 2, 2008 at 12:07:55 PM | Drawing Reference Planes in 3 Dimensions?
lunchtrayrider
3.5 Stars: 7 Votes
okay so i tried this one and the best solution looks like a rotating reference plane with a rotating reference line in it.  but its far from perfect.
Listing the Abilities of Reference Planes
Sun, Sep 9, 2012 at 9:24:07 PM
reference planes
Wed, May 24, 2006 at 10:19:12 AM
Center Reference Planes.......
Tue, Jan 30, 2018 at 9:48:46 AM
Locating Reference Planes in Elevation
Sat, Nov 1, 2008 at 8:05:13 AM
Detail Lines and Reference Planes
Tue, Sep 20, 2016 at 2:37:46 PM
Page generation time: 2.2894
