Forums >> General Discussion >> Revit Project Management >> Clash Detection
Mon, Jun 2, 2008 at 3:01:31 AM | Clash Detection
Allan1983a
I have drawn a structural model (i.e. just the steel) but want to be able to check if any of the mebers clash with each other, has Revit got the capabilities to do this? I am currently working on Revit Structures 2008.
Mon, Jun 2, 2008 at 6:01:19 AM | Clash Detection
Good time to learn ... run the clash detection and see what happens.  Tools - interference check.  Use your help menu too!
Mon, Jun 2, 2008 at 7:17:53 AM | Clash Detection
rkitect
rkitect Avatar
4 Stars: 29 Votes
We use NavisWorks at our office, and the comparison between the interference reports out of Revit and NW (while still lacking even in NW) are like night and day.  I'm sure you can use some css and xml to pretty up the Revit report, but I have not played with that yet.  The quick and dirty is that the interference check is a good first step to seeing if your model is clashing with other disciplines or even your own discipline.
GL!
Clash Detection
Fri, Oct 23, 2009 at 1:45:07 AM
How is BIM clash detection streamlining construction coordination for you?
Fri, Oct 31, 2025 at 6:15:30 AM
clash detection and ADA or ANSI errors
Tue, Oct 11, 2022 at 1:09:24 PM
Clash Detection Service???
Tue, Mar 18, 2014 at 2:13:08 PM
Door Openings Clash Detection
Thu, Aug 4, 2011 at 12:03:56 AM
Page generation time: 1.5735
