Forums >> Revit Building >> Technical Support >> Family Loading Problem
Fri, May 30, 2008 at 6:14:52 PM | Family Loading Problem
jchan
I created a mail slot from scratch and I can’t load it into my project. I created it under a new file and under the modeling tab, I went to create, casework…etc.
I saved it under the Casework Family category and when I load a component in and pick the file ,it says “the selected file is not a family file.” When I edit the file, it is a family file. It is a ".rfa" file.  Can you help me out? Am I doing something wrong?
Fri, May 30, 2008 at 6:44:34 PM | Family Loading Problem
TABEST
4 Stars: 4 Votes
Open the project you are trying to load it into, and the family file at the same time, the click on load into project (in the family file).  If you have already done this, then I recommend, resaving your file as a new name, and trying again...  If that doesn't work, then weird...
Mon, Jun 2, 2008 at 10:01:05 AM | Family Loading Problem
jchan
Thanks for your response.
However, the "Load into project" still doesn't show up. I saved as a different file as well and it doesnt' work either.
To create a new family file from scratch,do you just create a new file, under modelling, Create, then create a file under family category, save, then load into your project? Is this right?
Mon, Jun 2, 2008 at 10:12:27 AM | Family Loading Problem
TABEST
4 Stars: 4 Votes
file->new->family... choose one of the template files...
Mon, Jun 2, 2008 at 10:25:02 AM | Family Loading Problem
TABEST
4 Stars: 4 Votes
When you do a family the way you are doing it, you are creating an in-place family.
Mon, Jun 2, 2008 at 8:32:38 PM | Family Loading Problem
mhans
3 Stars: 10 Votes
Chances are you created a supposedly family with a  project template. That's the reason you cannot load it to your other project. Even if you saved it in the casework family, it still is not a family. it's a project with models. Recreated using a family template, either wall or floor based.
Motto: "No Post left behind"
Mon, Jun 2, 2008 at 9:22:01 PM | Family Loading Problem
jchan
Thank you...I will try that
Problem loading components
Mon, Sep 28, 2009 at 3:43:40 AM
Errror loading door family
Tue, Dec 1, 2009 at 10:10:48 PM
Revit 2012 having trouble loading profile family for wall sweep
Sat, Jun 11, 2011 at 3:20:42 PM
11
Text(family #1) not showing after loading into family #3
Mon, Jan 19, 2015 at 2:43:21 PM
Equipment Loading / Family Creation - Which family template? (2009-2011)
Fri, Feb 25, 2011 at 4:20:42 AM
Page generation time: 3.3923
