Forums >> Revit Building >> Technical Support >> OLD project with NEW template
Fri, May 30, 2008 at 4:48:03 PM | OLD project with NEW template
BDerrick
3.5 Stars: 3 Votes
Revit Arch2009
We have an existing project with an .rvt file type.  Recently we developed our own project template (.rte).  Is there anyway to put the two together so that our .rvt existing project has the same title blocks, views, and families as the .rte project template?  Or are there any suggestions?
Fri, May 30, 2008 at 8:27:49 PM | OLD project with NEW template
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
There really isn't a way to just move everything from one to the other. However, you will be able to move most of you annotations, sheets, Line weights, object styles, materials, filled regions, phasesprint settings, paper sizes, revision settings, text & dimension styles, wall types, floor types, ceiling types and what not using TRNSFER PROJECT STANDARDS under the file menu.
 When you do this a dialog will pop up and ask if you want to overwrite, new only or cancel. I usual do the overwrite to make sure that it copies what I need.
For anything not on this list like familes I usually load those in one at a time so I can check them and a lot of the stuff you can copy paste.
JUST BE AWARE OF ANYTHING THAT IS GETTING COPIED!!! Revit will warn you if it has renamed anything, families, groups, things like that. If this happens you will want to make sure that you remove the duplicates as this can balloon your file size rather quickly.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Template to Project
Tue, Jul 31, 2018 at 2:25:32 AM
save new template from project
Tue, Nov 21, 2006 at 7:16:15 PM
Changing a template to a Project
Tue, Feb 2, 2010 at 7:03:23 AM
Trying to make a template out of a project that had worksharing enabled
Thu, May 28, 2009 at 2:03:53 PM
Changing template to project
Sun, Dec 12, 2010 at 10:51:01 AM
Page generation time: 0.5247
