Forums >> Revit Building >> Technical Support >> Area Plans with Color Fill Through Walls
Fri, May 30, 2008 at 8:48:55 AM | Area Plans with Color Fill Through Walls
ttiefenbach
ttiefenbach Avatar
3 Stars: 2 Votes
I'm creating an area plan and I see the color fill in the appropriate areas.  However, I really need to see the color fill go to the next color fill.  In other words; I don't want to see the wall as white and 2 separate colors on either side of it.  Instead, I want the color fill to stop at the area boundary line and ignore the wall being there (as far as the color fill is concerned).
 Any suggestions?
Revit Architecture 2011
Fri, May 30, 2008 at 11:20:14 AM | Area Plans with Color Fill Through Walls
rkitect
rkitect Avatar
4 Stars: 29 Votes
-Go to Settings > Color Fills Schemes
-Find and select the scheme you are working with in the list on the left
-In the bottom portion of the dialogue, select "Foreground" in the "Display Color Fill in" option.
-Hit ok
Enjoy!
Edited on: Fri, May 30, 2008 at 11:21:03 AM
Fri, May 30, 2008 at 12:59:54 PM | Area Plans with Color Fill Through Walls
ttiefenbach
ttiefenbach Avatar
3 Stars: 2 Votes
I forgot to mention I was in Revit 2009.  Maybe what you're mentioning is in an earlier version, but I don't se it in 2009.  Any ideas where they hid that option?
Fri, May 30, 2008 at 1:03:49 PM | Area Plans with Color Fill Through Walls
ttiefenbach
ttiefenbach Avatar
3 Stars: 2 Votes
HA!, found it!  It's the the view properties, right about the color scheme option.
 Thanks for the help!
Wed, Sep 12, 2012 at 11:05:59 AM | Area Plans with Color Fill Through Walls
ISXXVII
REVIT 2012.  I have a room area color scheme that displays properly when set to Foreground.  But when set to Background it mostly disappears.  It seems as if the floor slab, which is actually a Foundation Slab, is covering most of the color scheme.   The rooms are located on 01 Level.  So are the slabs.  Any suggestions as to why Revit is not displaying the color scheme in the plan?
Mon, Oct 21, 2013 at 8:41:15 AM | Area Plans with Color Fill Through Walls
Kirsebom
I have the same problem with my color scheme. Somehow the floor is in the way of the colorscheme. Any1 knows a solution?
Thu, Oct 8, 2015 at 6:50:30 AM | Area Plans with Color Fill Through Walls
KimTaurus
KimTaurus Avatar
5 Stars: 3 Votes
For those who don't see the color scheme, even though it's activated: do you have a pattern set on your floor surface? In case it is set to a solid white, it "covers" the color scheme.
Area Legend not showing
Fri, Mar 14, 2014 at 1:00:17 PM
Custom Area plan
Mon, May 7, 2007 at 12:11:44 PM
Color fill in area plan convering walls, furniture etc.
Mon, Feb 26, 2007 at 9:16:40 PM
Color Fill in Building Sections
Mon, Jun 18, 2007 at 2:35:00 PM
CAD overlay visibility in color plans
Mon, Jun 4, 2007 at 4:56:27 PM
Page generation time: 0.8388
