Forums >> Revit Building >> Technical Support >> demension text color
Thu, May 29, 2008 at 9:40:04 PM | demension text color
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
Hi all, another dumb newbie question
I was looking at setting up templates to configure with our current office cad standards and guidlines.  We currently have the text on a dimension a green color where the dimension lines etc.. are red.  Ive noticed in Revit that within a dimension we only have 1 color option for the whole dimension.  Is there a way around this????
Fri, May 30, 2008 at 2:38:02 AM | demension text color
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm, I don't believe so.
Why are you using different colours for these items?  Its sounds a little like you are forcing AutoCAD operations on to Revit...  Do you actually print out in colour for this?
Just interested to know.
Regards,
Chris.
Sun, Jun 1, 2008 at 5:57:24 PM | demension text color
KennyGee
KennyGee Avatar
3.5 Stars: 3 Votes
No, we print out in B&W.  Im was just trying to replicate our CAD standards and guidlelines into Revit.  I see your point about trying to force Autocad operations into Revit.  Ive gotta be conscious on refining our standards to suit Revit and to meet best practise.
Tue, Dec 18, 2012 at 9:10:20 AM | demension text color
TLane1
TLane1 Avatar
This question seems to have come up on several forums, and the response usually comes back to something like this, "Why would you want to do something like this in Revit? Revit ain't Autocad."
I am working on a renovation to an existing building, and I built a model of the existing building in Revit (using cad drawings the client had on file).  These drawings, while close, are not exact.
I would like do drop dimension strings on my exising drawings and then check those dimensions on site.  It would be handy to have the dimension lines drawin in black with the dimension text drawn in a light grey.  I would then print out the drawings and head off to the site with my drawings and tape measurer in hand.  I could then write on top of any of the dimension text that doesn't check out.
Yes, I know I am getting picky with Revit. I could certainly print the dimensions and text as one color, but it shure would be nice to have that text just the right shade of grey....
Tue, Dec 18, 2012 at 9:34:38 AM | demension text color
I don't think the color of the text would change your process at all.  If you want to seperate existing dimensions vs new, then why not just another view  - existing..?
Tue, Dec 18, 2012 at 9:46:23 AM | demension text color
TLane1
TLane1 Avatar
Thanks for the quick response WWHub!
It's not that I want to differinteate existing dimensions from new.  I would like the dimension text grey so that when I write over it, my pen writing will read better.
For example... If I have modeled a wall that is 8'-6" long and it actually measures 9'-4", I would then write over the 8'-6" dim. text.  Once I have measured all the walls across the entire project, I would return to my office and update the existing building model to match my measurements.
Your are correct about the process being the exact same no matter what color the text is, but, IMO, the sheet of marked up dimensions would read better if the dim. text was light.
Tue, Dec 18, 2012 at 9:58:22 AM | demension text color
So do it!
Select all dimensions and over-ride color.
Tue, Dec 18, 2012 at 10:12:48 AM | demension text color
TLane1
TLane1 Avatar
Is it possible to change the text seperately from the dimension line color?
Tue, Dec 18, 2012 at 10:59:30 AM | demension text color
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
No, you can only change the whole dimension and text color.
Sat, Oct 15, 2022 at 7:49:42 AM | demension text color
morawaaa
Hi! I completely get the idea of different font color for the dimension lines. It is so handy to prepare the drawings with "empty" dimension lines ahead and then fill them while measuring the building on site. So much easier and fewer errors without the chaotic free-hand lines.
My trick is to manipulate the proportions of the font by scaling down the width factor and text size. This way i just get only the lines Smile
Sat, Oct 15, 2022 at 5:26:17 PM | demension text color
#11
You do know that you can over ride the text and just put in a character .... like a dot?
Mon, Oct 17, 2022 at 8:21:03 AM | demension text color
#12
marmiketin1
4.5 Stars: 10 Votes
As WWHub said just select your dimension, click on the value and ovverride with text and just use a period.
Mon, Jan 30, 2023 at 6:30:35 AM | demension text color
#13
stademock
Tue, Jan 31, 2023 at 1:47:01 PM | demension text color
#14
marmiketin1
4.5 Stars: 10 Votes
Make two different dimension styles. One that is black and one that ios grey. Place all the dimension strings you will need as the grey type. Copy all dimensions with ctrl+c and past in same place. All dimensions just pasteed will be selected still. Change their type to the black type. Override all the dimensions with text using either aperiod or a unicode unit separator. You could also haave the black dimension use a bigger text offset so its easier to select. The image is showing the two dimension lines not in the same place but the two dimensions will be place one over they other when pasted.
Different color backgrounds with text.
Tue, Jan 27, 2015 at 9:44:11 AM
revision text color
Mon, Mar 25, 2019 at 1:17:50 PM
Edit Color Scheme: "Color" parameter
Wed, Feb 23, 2011 at 10:12:00 AM
Export to DWG creating color overrides in text families
Tue, Feb 10, 2015 at 8:27:00 AM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Page generation time: 1.7727
