Forums >> Revit Structure >> Technical Support >> GENERAL REVIT QUESTION - help please
Thu, May 29, 2008 at 6:22:35 PM | GENERAL REVIT QUESTION - help please
ngubser
I have 2008 on my machine and am doing a job that needs to be in metric.
I have only the imperial installed.  When I go to reinstall that part of the package it says that revit is already installed.  I have found a library of revit struture content for 08 online and have downloaded it but it is all in one big unorganized group.
 Does anyone have a suggestion of an easier way than having to go reorganize all of these families?
 I thought we'd never do a metric project.
Now I know better.
 Would appreciate the help
THanks
Thu, May 29, 2008 at 7:47:37 PM | GENERAL REVIT QUESTION - help please
TABEST
4 Stars: 4 Votes
??? I'm actually not sure, you can switch your dimensions to read in metric, you can format each of your value fields in schedules... so I'm not convinced that you need to go to metric... couldn't you build it via inches and feet, and then switch up at the last minute before a deliverable?  Just a thought... work whith what you are used to working in, and then before printing a deliverable, switch your project settings such that length is in metric... just beware of any dimension types that do not use project settings...  good luck
Fri, May 30, 2008 at 4:10:38 AM | GENERAL REVIT QUESTION - help please
4 Stars: 205 Votes
Hi, here we use the metric dimensions but i think you can do what TABEST say...
Fri, May 30, 2008 at 11:41:39 AM | GENERAL REVIT QUESTION - help please
ngubser
My main concern is that my family names and object types won't convert like a W14X157 or whatever changing to whatever it's equivelant would be W155X943  or however those are made up sizes but that's my real concern.
Fri, May 30, 2008 at 12:21:29 PM | GENERAL REVIT QUESTION - help please
TABEST
4 Stars: 4 Votes
Maybe try reinstalling to one machine... see if you can customize the install to install both
Is this a Tips and Tricks forum or a side door to the General Discussion forum ?
Tue, Aug 22, 2006 at 11:05:45 AM
General Contractors Using Revit
Mon, Sep 29, 2008 at 2:09:34 PM
12
Importing General Notes
Wed, Feb 9, 2011 at 8:08:29 PM
creating General Notes (best practices/ efficient methods) 2017
Fri, Nov 17, 2017 at 4:37:25 PM
justification problems creating general notes.
Mon, Sep 21, 2015 at 9:24:19 AM
Page generation time: 3.8013
