Forums >> Revit Building >> Tips & Tricks >> Floor Areas and Shaft Areas
Thu, May 29, 2008 at 5:33:37 PM | Floor Areas and Shaft Areas
Scooby
I need to create a material take off for the floors on my project. Simple enough, but I need the TO to report both the area after the shaft openings and before. Revit gives me the area with the shafts deducted but how can I then create a formula so that I can also see next to it in the schedule a gross area TO including the openings as part of that area?
please help
THANKS
Sun, Jul 27, 2008 at 8:23:59 AM | Floor Areas and Shaft Areas
JustinT
Tricky one.... one thought may be to try using Design Options... create two options and have the floors duplicated in both and also in one have the shaft opening... then you can schedule the floors from each option into 2 separated schedule tables..
Otherwise you will need to create an additional formula column (calculated value) in you schedule table which looks at the area of the floor and then adds the area of the shaft (manual as I don't think you could link the saft area dynamically)
 Justin
Sun, Jul 27, 2008 at 10:09:00 AM | Floor Areas and Shaft Areas
Design options can really be complicated and cause you problems.  I think I would do it as two floors.  One is the floor with openings as you already have.  The other being just the shafts.  Call this floor "shaft openings" but make its material transparent.  If it causes you trouble in plans, you could always put in it a different workset that is turned off in all views.
Sun, Jul 27, 2008 at 10:39:38 AM | Floor Areas and Shaft Areas
JustinT
Ja true... they can be compicated... what is really needed is for the Revit development team to allow interaction between objects that work with the one you are scheduling such as floor slabs and shafts etc. A good example of this requirement is with my structural clients... they all want to be able to schedule the columns and the supports e.g. piles in one table and have them automatically marked with the same reference number.
One for the future releases i guess :o)
Justin
Tue, Jul 29, 2008 at 3:04:18 PM | Floor Areas and Shaft Areas
Scooby
thanks for the suggestions
Custom gross areas
Tue, May 3, 2011 at 7:51:13 AM
rooma area of several room areas
Mon, Apr 19, 2010 at 1:45:30 PM
Areas Plan
Tue, May 14, 2013 at 12:02:12 PM
Wall tile areas
Mon, May 4, 2009 at 7:19:25 AM
Calculating floor areas
Tue, Jul 21, 2009 at 3:42:43 PM
Page generation time: 9.2777
