Forums >> Revit Building >> Technical Support >> How to reduce lineweight for filled region
Thu, May 29, 2008 at 3:00:22 AM | How to reduce lineweight for filled region
Rams
3 Stars: 3 Votes
HI,
Can anyone guide me on the issue below?
I have to reduce the lineweight of filled region pattern. Is there anyway to make it halftone?
Thnx in advance
Now on the implementation stage....
Thu, May 29, 2008 at 3:33:59 AM | How to reduce lineweight for filled region
Dafpfy
3.5 Stars: 11 Votes
Hi,
Try selecting it , right click , overide grafics in view, by element, there you can set it to halftone,
in the normal properties you can olso set the color to white to make it invisible ( dunno if it will print white / invisible)
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Thu, May 29, 2008 at 3:38:43 AM | How to reduce lineweight for filled region
Rams
3 Stars: 3 Votes
That makes the boundary line as half tone also. I only want my hatch pattern to print lighter.
Any other suggestion plzz thnxx
Thu, May 29, 2008 at 4:57:50 AM | How to reduce lineweight for filled region
Dafpfy
3.5 Stars: 11 Votes
right click , overide grafics in view, by element, and set the surface pattern to grey or yellow or whatever,,,
peace is the path."
Mahatma Gandhi.
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Deleting Types From Filled Region Families
Tue, Sep 9, 2008 at 6:56:41 PM
filled region pattern color changes when drawing scale changes
Thu, Apr 14, 2016 at 7:32:06 AM
Lineweight on Surface Patterns?
Mon, Jun 15, 2009 at 11:54:52 AM
Tracing filled regions with linework
Tue, Mar 3, 2009 at 10:24:52 AM
Page generation time: 1.2762
