Forums >> Revit Building >> Technical Support >> Export to AutoCAD, folder structure
Wed, May 28, 2008 at 5:21:31 PM | Export to AutoCAD, folder structure
twebb
4 Stars: 1 Votes
Hello-
I am wondering if it is possible to export sheets and views to AutoCAD with a folder structure different than what seems to be the Revit default of putting them both in the same folder?
I am working on a project for a large government entity who has very specific requirements for final CAD drawing submissions.  Because of the size and complexity of the project, we would like to use Revit (v200Shadey, but my main concern is exporting the final drawings to AutoCAD.  If sheets and xrefed views go to a common folder, it will mean repathing hundreds of xrefs.  I would really like to avoid this.
Any suggestions would be appreciated.
thanks-
Wed, May 28, 2008 at 5:34:26 PM | Export to AutoCAD, folder structure
twebb
4 Stars: 1 Votes
That should read that i am using Revit version 2008, not 200 smiley faces with sunglasses.
silly emoticons.
Wed, May 28, 2008 at 6:15:16 PM | Export to AutoCAD, folder structure
TABEST
4 Stars: 4 Votes
Not 100% sure, but have you tried exporting to CAD with the "Xref views on sheets" unchecked?  I believe that this removes xrefs forcing the information to be in each specific file (yes, larger file sizes, but with terra byte drives, BFD.)  If this is not an option, then I'd recommend finding an Intern Smile
Wed, May 28, 2008 at 6:28:20 PM | Export to AutoCAD, folder structure
twebb
4 Stars: 1 Votes
this puts the line work from each view into model space of the single sheet file.  no xrefs.  not an option, i'm afraid.
Wed, May 28, 2008 at 6:49:49 PM | Export to AutoCAD, folder structure
TABEST
4 Stars: 4 Votes
definitely an intern then
export to autocad
Wed, Jul 6, 2005 at 7:41:50 PM
MEP AutoCAD Export issues
Sun, Mar 13, 2016 at 12:46:02 PM
Empty Revit Library FOlder Structure
Thu, Oct 14, 2010 at 2:20:30 PM
Export Revit to AutoCad
Sun, Jan 15, 2017 at 1:42:15 PM
3d view export to AUTOCAD
Thu, May 28, 2009 at 12:00:59 PM
Page generation time: 0.3028
