Forums >> Revit Building >> Technical Support >> Aligning surface patterns on Curved walls
Wed, May 28, 2008 at 3:34:30 PM | Aligning surface patterns on Curved walls
sharris2909
I'm on revit 09 and we are trying to align a surface pattern on a curved wall.  This is easy on a straight wall but I can't get it to work on a curved one.  Is this not possible or does anyone have a work around?  We are trying to align metal panel sections with a radius curtain wall mullions.
Suggestions
Sun, Jun 1, 2008 at 12:22:14 AM | Aligning surface patterns on Curved walls
mcuevas
I've always had issues aligning surface patterns on curved walls in Revit. The only way I have been successful is by dragging the line. This doesn't really allow you to snap to anything but it gets you close. The other thing you need to keep in mind is that there is a certain distance you have to drag the line before you see it actually move on the screen. What that distance happens to be, is still a mystery to me. It is never consistent when I do it. Just keep dragging the line over and eventually you'll see it move. Good luck!
Mon, Jun 27, 2011 at 3:55:59 PM | Aligning surface patterns on Curved walls
edelong
This has also always caused me fits, and this thread is something that always pops up when I hunt to see how to do it.  Fortunately for anyone else in the same boat, I'VE FIGURED IT OUT!!!
First I found this website...http://revitelemental.blogspot.com/2010/05/aligning-hatch-patterns-on-curved.html
But that only tells half the story.  What you really need to do is select the vertical line in the surface pattern, then switch to plan view.  THEN click rotate, and you'll see a dashed box that represents the vertical line in the pattern.  The axis should already be set to the curved wall's axis, so all you need to do is click on the box as your reference point, and where you want it as the end point.  Can't really align, but this is by far the most accurate I've gotten with vertical pattern lines on a curved surface.  Beats dragging it and hoping for the best, anyway.
Tue, Jun 28, 2011 at 7:06:28 AM | Aligning surface patterns on Curved walls
I believe the last time I had this problem, I added a temporary straight wall segment that was joined tangentially with the curved wall.  I then aligned the pattern in the straight wall area and then deleted the straight wall.
Tue, Mar 3, 2020 at 9:06:53 AM | Aligning surface patterns on Curved walls
Mantaszs
@edelong this is gold man, thanx!
Thu, Mar 5, 2020 at 11:50:31 PM | Aligning surface patterns on Curved walls
erpdubai
looking same
Surface Patterns
Wed, Mar 4, 2009 at 11:24:15 AM
curved surface
Tue, Nov 6, 2018 at 7:03:42 AM
Surface Patterns in Perspective
Fri, Jan 27, 2012 at 7:04:34 AM
surface patern not aligning
Fri, Jul 20, 2007 at 9:38:40 AM
Aligning model patterns on a curved wall
Thu, Feb 4, 2010 at 5:21:16 PM
Page generation time: 2.1933
