Forums >> Community >> The Studio >> Procedural Cities
Wed, May 28, 2008 at 11:59:16 AM | Procedural Cities
sjmoir
I'm not familiar with Revit's capabilities so would appreciate anyone's opinion on this. I'm looking for a way to generate fairly simple buildings quickly for large planning projects like this one I worked on recently. I normally receive a .dwg with closed polyline building footprints, which I bring into max and extrude and texture map. I'd really like to push this a bit further, it works well at a distance but not close up. I've got my eye on this pretty amazing program, CityEngine, but we have a few unused Revit licenses in our office and wondered if I could use one of them to achieve a similar result.
Could I create a building (from a closed polyline) with a very simple facade system, then apply the same steps to another footprint? Does Revit allow some sort of scripting like this? The models wouldn't need interiors and don't need to be "smart". If I can clarify my question let me know, cheers.
Wed, May 28, 2008 at 12:13:30 PM | Procedural Cities
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
You can use the massing in revit and very easily apply wall types, roof systems and what not to the masses, but I'm not sure that you will be able to achieve what City Engine can as fast as it can. City Engine is designed to handle large scale cities rather easily where as Revit might start to bog with that many mass objects plus City Engine has a built in scripting tool to aid with building editing.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Thu, May 29, 2008 at 10:36:17 AM | Procedural Cities
sjmoir
OK, thanks Brett, that's pretty much what I thought.
Procedural Maps
Fri, Sep 28, 2007 at 10:45:29 AM
Modeling Cities
Thu, Nov 17, 2011 at 7:53:12 AM
Manage place and location / City? Longitude?
Wed, Oct 31, 2007 at 7:57:51 PM
Render Materials
Thu, May 4, 2006 at 11:09:13 AM
Wall Ratings - Export to DWG for Consultants
Mon, Dec 6, 2010 at 2:20:44 PM
Page generation time: 0.0111
