Forums >> Revit Building >> Technical Support >> existing, demo and new roof
Tue, May 27, 2008 at 9:16:26 PM | existing, demo and new roof
smartDESIGN
Addition to a small, rural library and we are going to roof over the entire bldg.  I built the model of the existing building and selected demo for the roof.  When I add the new roof in the new construction phase, the walls do not want to join to it because they are already joined to the demo roof.  How can I make an existing walls attach to an existing roof for a demo drawing and to a new roof for the proposed work?
Wed, May 28, 2008 at 6:24:47 AM | existing, demo and new roof
Are you really demo-ing the roof structure or just the roof finish?  If it's just the roofing, then split your roof into two components.   If you are demo-ing the structure, why not use the same roof for both new and demo plans?  Just handle it with 2d work or by over-riding in view how the roof looks.
If you are demo-ing the structure and the walls have to be changed to meet the new structure, then you might try to do using design options.
Wed, May 28, 2008 at 8:21:30 AM | existing, demo and new roof
smartDESIGN
Thanks for the response.  We are demolishing the roof structure and putting on a very different roof.  Design options is probably the way to go, but as a newbie I have seen it done but not played with it yet.
How Do I Create Existing and Demo Floor Plans From Linked Model
Thu, Dec 20, 2012 at 9:20:06 AM
demo opening in existing wall
Tue, Feb 21, 2012 at 2:38:17 PM
Demo shapes from existing walls
Thu, Feb 16, 2006 at 7:57:57 PM
Oldie but Goodie: Door Infills...ARRRGH!
Tue, Mar 15, 2016 at 4:20:25 PM
Existing floor with a new stair opening... need help with phasing
Thu, Apr 25, 2013 at 11:10:34 AM
Page generation time: 0.9681
