15 Users Online (13 Members):
Forums >> Revit Structure >> Technical Support >> Joist sitting on Sloped beams
Hello, I am currently working on REvit Structure 2009 and I have 2 questions for anyone who can help me. 1) I have a sloped beam line and I would like for the Joist to sit on the beam no to float, do I have to Individually drop each one individually or is ther ea setting I can change so this happpens naturally? 2) on corase I am trying to show a simbolic cutback (i.e. Joist not touching beam) On one end the joist cut back from the ocncrete wall, onthe other ende the joist join the beam and I want it the other way around. Can someone explain me how to fix this please? Cheers and I look forward ot reading the repsonses. Vanrevit
Welcome to the REvitlution!!! |
For your first query: Make a reference plane along the direction of your joists. Use "pick a plane" from choices and pick the top of the beam where the joists would line-up. For your second, edit the element property, under Construction, give a negative value to Start or End Extension to move end of joist away from support. Do the reverse to extend towards support.
Motto: "No Post left behind" |
Sloped joist line type |
Thu, Nov 25, 2010 at 12:25:02 PM
Joist Seats on sloped joists |
Wed, Oct 24, 2012 at 1:27:46 PM
13
Sloped Structural Joist |
Mon, Nov 7, 2005 at 12:14:32 PM
Sloped joist seat |
Wed, Oct 24, 2012 at 1:26:11 PM
Joist Top Elevation |
Thu, Feb 27, 2014 at 8:58:17 AM
