22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Revit Roofing
1 Posts No Rating |
I need to create a roofing plan, but all i can see is this "mass". i have adjusted to cutplane, height, and depth properties to no avail. How do i see the beams that make up the roof?
Adjust view detail to fine. Check visibility for structural framing, column, beam systems.
Motto: "No Post left behind" |
13 Posts No Rating |
Do you have a sheating on your roof? make sure that that is either off or transparent. Are you beams drawn as framing? you might also just turn the roof off, unless you want the vallys and ridges to show up on your plan. Make sure that Framing is turned on in your visibility graphics and that they are not hidden in view.
Roofing Material Look alike |
Wed, Nov 21, 2012 at 5:35:57 PM
sloping roofing |
Wed, Mar 9, 2005 at 1:21:52 PM
align Revit's asphalt shingle roofing in plan view to sloping side |
Wed, Aug 12, 2020 at 4:47:28 PM
Altering roofing structure in section views R2012 |
Thu, Jul 19, 2012 at 7:32:50 AM
Tile Roofing |
Wed, May 31, 2006 at 8:06:23 AM
