11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Revit 2009 material saving
Is it possible to somehow save the materials other than leave them in the project and later tresfer them using the "trasfer project standards tool"?
hi, Unfortunately it's the only way you save your materials (walls, doors, windows, and so one), because in this version THEY have the "GLOSSY IDEA" to remove from the program a "USER LIBRARY", in the other versions you have the possibility to save your materials in a "USER LIBRARY" BUT IN THIS "THEY" TOOK this possibility....
I know, but than I don't want to go back to accurender. It seems that this will be changed as there is an option in settings called "Render appearance library" which does absolutely nothing (only thing is to press ok), I would guess that this will be the place to import or save materials and perhaps synchronize with your main material library Thanks, I wanted to be sure
Saving frpom 2010 to 2009 |
Wed, Jul 13, 2011 at 2:13:05 PM
Revit 2009- 'Cut-out' image for materials, faulty |
Mon, Sep 29, 2008 at 4:13:56 PM
Revit 2009 Additional Material Request |
Thu, Aug 7, 2008 at 3:21:22 AM
2009 subsurface material display |
Thu, Apr 24, 2008 at 8:07:25 PM
REVIT 2009 - MATERIALS |
Tue, May 5, 2009 at 10:01:40 AM
13
