Forums >> Revit Building >> Technical Support >> sweep massing help
Sun, May 25, 2008 at 10:01:34 AM | sweep massing help
hammer87
hammer87 Avatar
3 Stars: 4 Votes
im currently working on modleing the Planet Express building from the show Futurama. I am working on the tower and i am using a swept mass for the base. what happens is that the top and base portiations of the mass are not even. how do i get them to be even?
My Futurama Fan Fiction 'Hammer087' - http://futurama-madhouse.com.ar/fanfic/indexh.shtml#hammer087
Sun, May 25, 2008 at 12:54:22 PM | sweep massing help
4 Stars: 205 Votes
Hi Hammer, i think you sketch the path with some inclination, in a elevation view see if the model have an inclination, if so, edit the sweep and rebuild your path in a elevation view (vertically).
Sun, May 25, 2008 at 1:20:10 PM | sweep massing help
hammer87
hammer87 Avatar
3 Stars: 4 Votes
i checked the incline and it doesnt look like there is one, and when i do the path i do it using the front of the building and use the top for the profile.
Edited on: Sun, May 25, 2008 at 1:22:05 PM
Sun, May 25, 2008 at 1:30:00 PM | sweep massing help
4 Stars: 205 Votes
An optical illusion?
Sun, May 25, 2008 at 1:33:30 PM | sweep massing help
hammer87
hammer87 Avatar
3 Stars: 4 Votes
well what i just did was sketch the path from the top view, then sketched the profile from one of the elevation views. the result is below
Edited on: Sun, May 25, 2008 at 1:41:49 PM
Sun, May 25, 2008 at 1:41:25 PM | sweep massing help
4 Stars: 205 Votes
No, i said to sketch the "PATH" in a elevation view just like you did, and the profile in REF LEVEL...
Sun, May 25, 2008 at 1:43:40 PM | sweep massing help
4 Stars: 205 Votes
Can you put the images from that element in ELEVATION and a better image in a 3D VIEW?
Sun, May 25, 2008 at 1:46:46 PM | sweep massing help
4 Stars: 205 Votes
ooow, i see now much better,, seems ok, you can do that, Path in Plan and Profile in elevation.
Sun, May 25, 2008 at 2:24:38 PM | sweep massing help
hammer87
hammer87 Avatar
3 Stars: 4 Votes
well heres the final product. after  i finished the sweep, i did a wall by face
Sun, May 25, 2008 at 2:45:14 PM | sweep massing help
4 Stars: 205 Votes
Yeah, almost there... keep going...
Sat, Feb 21, 2009 at 12:40:17 PM | sweep massing help
#11
hammer87
hammer87 Avatar
3 Stars: 4 Votes
Well i'm back to working on this project finaly. Now im having issues with the sphere and placing windows. Heres the file. Also included is the windows i wish to use.
Sat, Feb 21, 2009 at 2:29:13 PM | sweep massing help
#12
4 Stars: 205 Votes
Hi Hammer, glad to see you man, you must create the windows in a "Generic model Face Based"...
Wed, Feb 25, 2009 at 8:21:57 AM | sweep massing help
#13
hammer87
hammer87 Avatar
3 Stars: 4 Votes
I see, and how would i do that? I have absoultey no clue.
Wed, Feb 25, 2009 at 8:45:45 AM | sweep massing help
#14
4 Stars: 205 Votes
Hammer, You are kidding, right????
Wed, Feb 25, 2009 at 8:54:09 AM | sweep massing help
#15
hammer87
hammer87 Avatar
3 Stars: 4 Votes
Nope. Like i said it's been awhile since i last used Revit.
massing
Fri, Feb 27, 2009 at 3:52:43 PM
13
Where are *blend, sweep...* commands in Massing & Site
Sat, Mar 27, 2010 at 8:45:29 AM
Roof massing
Wed, Apr 29, 2009 at 10:51:01 PM
why my massing can't not be a solid?
Fri, Feb 11, 2011 at 8:26:42 PM
Massing
Mon, Jun 22, 2009 at 9:18:46 AM
Page generation time: 2.9231
