Forums >> Revit Building >> Technical Support >> Families & Constraints
Sat, May 24, 2008 at 6:53:11 PM | Families & Constraints
Voron
Voron Avatar
2.5 Stars: 3 Votes
Revit Architecture 2008
I'm currently working on a piece of casework that has mesh shelves that move vertically with the variable height of the unit. The mesh shelves sit within a wooden frame.
The goal is to perfectly constrain a mesh with variable Width, Depth, and Elevation (Height). The mesh is constructed with a series of equidistant parallel lines that run perpendicular to each other along the entire distance of the Width and Depth.
It is constructed with model lines constrained to reference planes.
Width....Perfect
Depth....Perfect
Elev. (Height) FAILED
I do not understand how to get the entire mesh to parametrically move vertically. I've also tried to move an array parallel to the ground plane vertically with undesirable results. I'm at my whits end with this.
I don't know how to resolve this issue.
Please help.
...The File is attached. Play with the height parameter and you will see the problem
Edited on: Sun, May 25, 2008 at 3:51:57 PM
Edited on: Wed, May 28, 2008 at 12:08:16 PM
Sun, May 25, 2008 at 3:36:57 AM | Families & Constraints
4 Stars: 205 Votes
Hi "Voron", can you put your model here to download so we can see what's going on?
Wed, May 28, 2008 at 4:10:47 PM | Families & Constraints
rkitect
rkitect Avatar
4 Stars: 29 Votes
Got it!  Enjoy!
The three files are:
Mesh Shelf Cabinet - Parent Family
Mesh Shelf - Shelf Family, nested into Cabinet Family
Mesh - Mesh family, nested into Mesh Shelf Family
This was necessary to get the array to work correctly.  The parent family has all of the parameters linked to control the shelf and mesh parameters.  I had to change 2 dimensions in your original model to be controlled by the "Frame Thickness" parameter in order for the shelf to work correctly.  You only need the parent family file to use this family, but I included all three so you can easily see how I constructed the family.
The issues was taht the model lines were not actually attaching themselves to a work plane (even though it looked like it), so when you changed the height of the plane the model lines were "associated" with, they didn't move.  What I did is made a family with just a model line in it, nest it into the shelf family.  This way i can control the height of the family instead of the height of the model plane.  When the height of the family changes, the model line has no choice but to move with it.
Let me know if you have any issues.  Good luck!
Edited on: Wed, May 28, 2008 at 4:14:49 PM
Wed, May 28, 2008 at 4:40:00 PM | Families & Constraints
Voron
Voron Avatar
2.5 Stars: 3 Votes
Thanks Rkitect!!!
This is exactly what I wanted to do. Call me simple... But to me this is the work of genius!
Thank you for showing me how. I will give credit where credit is due.
Edited on: Wed, May 28, 2008 at 4:59:09 PM
Parameter Data - What's the difference between Constraints & Dimensions.
Sun, Dec 21, 2008 at 12:19:17 PM
Wall based families and constraints.
Tue, Apr 11, 2006 at 8:54:28 PM
Family Instant Parameter Constraints Offset
Fri, Feb 1, 2013 at 2:41:00 PM
Constraints r not satisfied
Sat, Aug 23, 2008 at 1:27:36 PM
Reasigning associated level/base & top constraints on a masive model
Thu, Oct 11, 2012 at 12:51:30 PM
Page generation time: 2.7695
