Forums >> Revit Building >> Technical Support >> Revit 2009 Rendering Issues
Sat, May 24, 2008 at 3:13:18 PM | Revit 2009 Rendering Issues
jbh322
I'm using the 30 day trial of Revit 2009 and am having trouble getting any kind of sky to show up when I render. Does anyone know what I might be doing wrong. The background just shows up gray.
My settings are medium quality, exterior sun, and sky few clouds. Thanks
Sun, May 25, 2008 at 3:43:52 AM | Revit 2009 Rendering Issues
4 Stars: 205 Votes
Hi there, do you try to change the elevation camera? for example: see from bottom to top, put camera source in 1.75m and camera target 5.00m. The Revit 2009 in render now, it's like 3Ds max or Rhino, have a "Base" (gray) and if we don't put some "site" appears gray, but when we change the perspective view start appear the blue sky....
Thu, Jun 12, 2008 at 12:33:31 PM | Revit 2009 Rendering Issues
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I have question. In the following image, why is the sky stopping just below the top of the scene?
Fri, Jun 13, 2008 at 11:59:45 AM | Revit 2009 Rendering Issues
airfoil
Could it be that your camera is high enough that you're gaining horizon?
Fri, Jun 13, 2008 at 12:04:09 PM | Revit 2009 Rendering Issues
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Well I think that may be the issue. I have my camera set a 20'-0" and the target at 18" in elevation. The site is high at the location of the camera so I have to have it that high. I was just wondering if I had missed a setting somewhere and could adjust the horizon. I know I could put more trees on the site to "hide" the horizon but I don't really want to.
Fri, Jun 13, 2008 at 4:02:48 PM | Revit 2009 Rendering Issues
4 Stars: 205 Votes
Hi JAMES, if you just look my post above i think i awnser the question, they "put" Mental Ray like 3DS MAX or Rhino, you have "like"a Horizont line (grey), it's not a issue, when we don't have a "Site" "he" put that "line" to define the horizont line like MAX or Rhino...
Fri, Jun 13, 2008 at 4:24:34 PM | Revit 2009 Rendering Issues
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Thanks, I guess I will just have to live with it then.
Fri, Jun 13, 2008 at 4:29:28 PM | Revit 2009 Rendering Issues
4 Stars: 205 Votes
Yeah James, me too, but I'm already accustomed with that in MAX and RHINO, so... But i think it's better like this because in 2008 if we  don't put the SITE in model (LARGE) the "SKY" appears just like 10 feets...
Fri, Jun 13, 2008 at 4:33:21 PM | Revit 2009 Rendering Issues
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
That's true. I just hope Autodesk eventually gives us the ability to render with a custom background. In the meantime I will work around it.
Fri, Jun 13, 2008 at 4:41:18 PM | Revit 2009 Rendering Issues
4 Stars: 205 Votes
Yeah, i when "they" change 2008 to 2009, with Materials i just have a "Crash" because i have hundred of materials created and now i have to just REBUILD again, it's like a Knife in my Chest...
Edited on: Fri, Jun 13, 2008 at 5:11:55 PM
Mon, Nov 17, 2008 at 9:39:57 PM | Revit 2009 Rendering Issues
yrneg
3 Stars: 2 Votes
hello im just wondering about how to render trees clearly in revit?and also it kinda look like grayish and pale rather than green..can anyone have some helpful tips on proper exterior setup?....thanks
yrneg@yahoo.com/blitzwing_17@gmail.com
genry_07
Fri, Sep 4, 2009 at 7:29:39 PM | Revit 2009 Rendering Issues
aWorulz
if you trees are being rendered white. go to materials and go to the specific material used and change the rendering colour. it has a default of with so just changing it to the correct colour wiill give you the colour when it is rendered.
Sat, Sep 5, 2009 at 3:43:18 PM | Revit 2009 Rendering Issues
#13
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Do what aWorulz suggests: check your materials in Settings--> Materials...One suggestion: rename you materials, i.e. Render Material 200-200-200 to Leaves or whatever.....
Sat, Sep 5, 2009 at 4:00:41 PM | Revit 2009 Rendering Issues
#14
tim123
4 Stars: 19 Votes
Are they RPC trees in 2009 or 2010?  These can appear grey / green, but it depends on lighting conditions and the type of tree.  If you post an image we can see what you mean.
Sun, Sep 6, 2009 at 10:35:29 AM | Revit 2009 Rendering Issues
#15
erland73
erland73 Avatar
4.5 Stars: 85 Votes
If they are RPC trees, also make sure their version, if they are RAC 2008 RPC trees and you're using RAC 2009, they'll appear grayish....
Rendering RPC issues
Thu, Jun 11, 2009 at 3:55:31 PM
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:50 PM
2009 Rendering has white spots!
Thu, Sep 4, 2008 at 5:56:09 PM
Helping rendering in 2009
Sun, Apr 19, 2009 at 8:24:59 AM
Page generation time: 2.1367
