Forums >> Revit Building >> Technical Support >> Wood stair Family or Details
Sat, May 24, 2008 at 1:34:48 PM | Wood stair Family or Details
rgaaia
2008. I am not happy with the stair configuration and details created by the Revit modeler for wood stairs.  they have some goofy elements in the model and can't make a simple wood stringer. riser and tread model to add vinyl floor and treads and risers!!.....any idea of other ones out there to assist me???
 thanks for your help!!
Wed, Aug 10, 2011 at 10:26:23 PM | Wood stair Family or Details
kbel4
Hey, did you ever get a good answer?
Thu, Aug 11, 2011 at 7:46:56 AM | Wood stair Family or Details
For some reason, we can't add patterns to treads in stairs but they will render correctly.
I suggest you look at the example stairs (BTW - later versions are  no longer posted so look in the 2009 library.)
The on-line library is here: http://revit.autodesk.com/library/html/index.html
The stairs and other items are under the Revit instruction and Help samples.
Can not swap out one stair family for another
Thu, Sep 19, 2013 at 12:24:19 PM
Wood floor way too shiny.
Tue, Dec 14, 2010 at 7:32:39 AM
wood deck family
Mon, Nov 23, 2009 at 11:19:20 AM
How to Apply Wood Material to a New Family Member [ 1 2 ]
Mon, Jul 13, 2009 at 2:18:09 PM
15
Wood Siding
Fri, Nov 22, 2019 at 3:17:58 PM
Page generation time: 0.8953
