Forums >> General Discussion >> Wishlist >> "ADA Clearances" in families
Fri, May 23, 2008 at 4:08:46 PM | "ADA Clearances" in families
psemrau
Well, we design healthcare areas in our projects, it would be a nice feature to have a "clearance" area related to a family, not just a few dashed lines related to a model, but actual "room like" volumes or areas that give warnings if any other object is inside their boundaries.  Like clearances in showers, toilets or around beds, or room sizes. It would be cool to have warnings if something is "non compliant", or to check in a schedule if there is an issue with an instance...
just ideas
Fri, May 23, 2008 at 4:13:37 PM | "ADA Clearances" in families
4 Stars: 205 Votes
Some day.... it could be....
Sun, May 25, 2008 at 3:59:00 PM | "ADA Clearances" in families
Voron
Voron Avatar
2.5 Stars: 3 Votes
I agree. The neat thing about it too is that the idea is totally plausible and practical. I mean everyone is in the interest of convenience and saving time.
All it would take is someone with the knowhow to sacrifice some of their own time. You know... take one for the team
Edited on: Sun, May 25, 2008 at 3:59:58 PM
Mon, May 26, 2008 at 10:51:35 AM | "ADA Clearances" in families
For now though, it's easy to build your families with the ADA clearances shown and a simple switch to turn them on or off.  I do them as a linetype and turn them on or off through VG.
Fri, Sep 2, 2011 at 2:35:01 PM | "ADA Clearances" in families
EricOlson
I wrote about this same problem recently on my blog. I ran accross this thread while I was researching a solution, and thought I'd give back to RevitCity, rather than just use it for research! Hope this helps someone out!
http://bimgineering.blogspot.com/2011/09/create-hatched-clearance-for-revit_02.html
Sat, Sep 3, 2011 at 10:19:42 AM | "ADA Clearances" in families
I have changed my mind since my post in 2008.  I would not put ADA clerances in the door families.  No need to do this.  I would use a simple 2D line only family that can be placed when needed.  No need to build a complicated door family.
Sun, Dec 11, 2011 at 11:17:32 AM | "ADA Clearances" in families
phtshpguy
I would rather have a couple of slightly more complicated families than just more families, the list within the properties panel gets big enough as it is. The doors that I am using have multiple types within the family that allow for flush, vision, half, and full lites.  They also have a couple simple extrusions that do not appear hardly anywhere and have a ADA category to isolate them for the sake of visibility.  This way you can run an interference check between walls and doors an eliminate careless placement of doors that can cause a potential change order.
Tue, Sep 11, 2012 at 10:34:16 AM | "ADA Clearances" in families
koolair
4.5 Stars: 2 Votes
My clearance zones in RME 2012 all follow the shading type I select for the view.  I want it to be transparent no matter what.
I even go into the family, select the clearance extrusions, hit clearance and select clear glass.  Save, load, and still no dice.
Any thoughts?
PS - I even went into object styles in Visibility Graphics (while in the project) to change the settings for Mechanical ---> Clearance.  Nothing.  Hope someone can help me out.
ADA symbols???
Wed, Aug 5, 2015 at 9:17:21 AM
How do you change a "generic model" family into a "mechanical equipment" family?
Fri, Apr 6, 2018 at 6:18:19 PM
ada grab bars for 8.1
Thu, Feb 22, 2007 at 4:12:24 PM
How to make a "Model in-place" a "Family"
Thu, Mar 17, 2011 at 5:07:59 PM
Creating ADA Sheet in Revit Template
Wed, Nov 9, 2011 at 11:33:10 AM
Page generation time: 1.5878
