Forums >> Revit Building >> Technical Support >> Associate detail lines/components with specific items
Fri, May 23, 2008 at 12:20:10 PM | Associate detail lines/components with specific items
jmerrick
I am using Revit Architecture 2009.
My question is an attempt to find information that "I think" I ran across recently but cannot find again.  I am fairly certain that I found some reference to being able to associate detailing to a specific item so that when that item is cut in section or by detail callout that the associated information would show when the view was set to the appropriate scale.  I may have been dreaming at the time but I am fairly certain I was awake.
For example, in the case or a floor slab you may tie a detail group/component to that slab and set it up so that when the slab edge is shown a detail/section cut at a larger scale the view would include reinforcing, insulation, etc.
If anyone can confirm that this is possible and knows what it is called and/or how to do it, please let me know so I can stop going out of my gourd over it.
Fri, May 23, 2008 at 1:57:20 PM | Associate detail lines/components with specific items
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I don't think it can be done for system families (i.e. walls, floors, ceilings, curtain grids) but it can for component families. I the component family you can attach a detail component and define how it appears. For example, I have a counter family that we show with a specific wood molding around the edge. When I cut a section thru that family it show the detail component I have attached. It only shows in section too, not in elevation.
Visibility/Graphics and Detail Components
Wed, Feb 23, 2011 at 2:53:36 PM
lines and detail components
Tue, May 7, 2013 at 11:46:36 AM
Existing items in a detail callout
Wed, Oct 20, 2010 at 3:40:57 PM
Detail Components with Demo Objects
Tue, Dec 30, 2008 at 4:34:29 PM
manually associate section mark to a specific view
Fri, Apr 3, 2009 at 1:11:54 PM
Page generation time: 2.3022
