Forums >> Revit Building >> Technical Support >> rotating detail component
Fri, May 23, 2008 at 10:14:18 AM | rotating detail component
gofastwin
Is there a way to make a detail component that when placed requires rotational alignment?  To put it in simpler terms, I have a flashing profile.  When I place it, after I click to set it down in the view, I want it to rotate around its origin (not its center) and align with my next click.  This would make it easier to place, then align with roof slope.  A sort of universal flashing tool.
Tim
Fri, May 23, 2008 at 3:52:16 PM | rotating detail component
There are many things you can do here but the best is this.  When you create your detail element, set the two reference planes as "defines origin" and build your component accordingly.
Now, as you place your component, hover near the item you want to align to and hit the space bar.  The componet will automatically rotate to align with what is close.  If it is not the rotation you want, hit the space bar again and it will give you another option.  When it is rotated right, you insertion point will then place it correctly.
Tue, May 27, 2008 at 7:39:40 AM | rotating detail component
gofastwin
Thanks, that is exactly what I needed!!  Works great!
Getting angle parameter for a plywood fill region detail component to work SMART
Wed, Jan 15, 2014 at 7:27:39 AM
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:15 PM
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:45 AM
Rotating Crop View - Detail Moves Randomly?
Mon, Sep 24, 2007 at 11:20:06 AM
CREATING DETAILS USING DETAIL COMPONENT
Mon, Jun 26, 2006 at 4:00:03 PM
Page generation time: 2.0047
