Forums >> Revit Building >> Technical Support >> Confusion on Rooms
Fri, May 23, 2008 at 9:37:22 AM | Confusion on Rooms
Rams
3 Stars: 3 Votes
I have one column coming in between one of the room. Now when i do the column encasement using wall the room  area gets changed. How can i get my actual area with column encasement?
Thnx in advance
Now on the implementation stage....
Fri, May 23, 2008 at 9:41:51 AM | Confusion on Rooms
4 Stars: 205 Votes
Hi, pick in the column go to properties and uncheck "Room Bounding"
Fri, May 23, 2008 at 9:59:16 AM | Confusion on Rooms
Rams
3 Stars: 3 Votes
The column is coming from the one of the revit link so that option is not possible.
Fri, May 23, 2008 at 10:15:31 AM | Confusion on Rooms
JHanby
3.5 Stars: 3 Votes
Try unchecking the room bounding on the walls.
Fri, May 23, 2008 at 10:24:44 AM | Confusion on Rooms
4 Stars: 205 Votes
In the left side "Room and Area" Settings-At wall finish, then pick in Area Plan then Area boundary and select the perimeter...
Fri, May 23, 2008 at 10:53:27 AM | Confusion on Rooms
Rams
3 Stars: 3 Votes
I figured it out. After selection the column encasement wall i uncheck the room bounding as suggeted by typhoon and everything is OK. But i think the elements from the link should be more inteliigent.
Anyway thnx everybody
rooms??
Tue, Oct 29, 2013 at 11:10:18 AM
tags, symbols and annotation confusion
Thu, Jan 17, 2008 at 11:13:31 AM
Deleting Rooms from Schedules
Tue, May 8, 2012 at 8:30:32 PM
Rooms within Rooms? I think...
Tue, Nov 9, 2010 at 11:45:56 AM
Programming spaces/rooms in Revit
Fri, Jun 21, 2013 at 9:20:34 AM
Page generation time: 0.3995
