21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Making Filled Pattern
26 Posts No Rating |
I'd like to create my own filled pattern... how do i do that? is there a software I d need to download to create a pattern and set it in either model or draft type.. then save it in .pad file.
Is there any software I can use?
Thanks
One way is to create the new pattern in AutoCAD (make sure the scale is large).
Save the File.
Import into Revit.
Explode the import.
Save as a new Revit project.
In new projects, use "Transfer Project Standards" (File containing pattern must be opened).
Push button that says "Check None"
Place check next to "Fill Patterns"
Voila!
How in the world do you know that? I couldn't figure it out!
I got it now, thanks!
filled region pattern color changes when drawing scale changes |
Thu, Apr 14, 2016 at 7:32:06 AM
Blank filled Region |
Fri, May 2, 2008 at 12:30:12 AM
Transparent Solid Filled Line-Based Families |
Tue, May 10, 2022 at 8:42:20 AM
change linetype of a hatch pattern |
Mon, Oct 5, 2020 at 7:58:40 AM
Filled Region Not covering wall surface pattern |
Mon, Apr 25, 2022 at 8:09:09 AM
