Forums >> Revit Building >> Technical Support >> how do i make a light shine a different colour?
Fri, May 23, 2008 at 8:06:38 AM | how do i make a light shine a different colour? Revit 2008)
brynn
pls help, I would like some the light fittings in my project to shine a different light accept clear white light. maybe dark blue light?
Edited on: Fri, May 23, 2008 at 8:13:12 AM
Fri, May 23, 2008 at 8:20:07 AM | how do i make a light shine a different colour?
4 Stars: 205 Votes
Hi, what version of Revit do you use?
Fri, May 23, 2008 at 8:21:59 AM | how do i make a light shine a different colour?
brynn
Hi, sorry.
 Revit 2008
Fri, May 23, 2008 at 8:28:55 AM | how do i make a light shine a different colour?
4 Stars: 205 Votes
If you use Revit 2009 you have very options to do that, in RAC2008 i never do that but you can try a "Trick", put with "Create in place" an object in front of your light and in the propertis choose glass and change the prop. of that glass (change the color of glass = blue)...
Fri, May 23, 2008 at 8:29:15 AM | how do i make a light shine a different colour?
4 Stars: 205 Votes
Give me a Feedback, ok?
Fri, May 23, 2008 at 8:35:53 AM | how do i make a light shine a different colour?
4 Stars: 205 Votes
You also can change the properties of your light and give them a new material in "Material Shade"
Fri, May 23, 2008 at 8:55:23 AM | how do i make a light shine a different colour?
brynn
doesnt seem to work...Sad
Fri, May 23, 2008 at 9:04:52 AM | how do i make a light shine a different colour?
coreed
coreed Avatar
4 Stars: 16 Votes
if you are using pre-2009 try this
http://www.revitup.co.za/main/page_tips__tricks_coloured_lights.html
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, May 27, 2008 at 7:21:38 AM | how do i make a light shine a different colour?
brynn
seems like it doesnt want to work if you use a ceiling based light fitting created by yourself. but it works with the standard metric lightin fixitures... Sad
case closed...
Shine some light
Mon, Sep 24, 2012 at 9:47:27 AM
trying to make custom light fixture w/ 2 light sources - need help
Mon, Jun 22, 2009 at 6:23:45 AM
Changing the Colour of a Material
Fri, Nov 16, 2012 at 3:21:06 PM
cannot fiure out how to make linear light fixure give off linear light
Tue, Jun 16, 2009 at 10:24:57 AM
Lighting fixture problems
Mon, May 8, 2017 at 10:43:49 PM
Page generation time: 0.5023
