Forums >> Revit Building >> Technical Support >> Area and parking parameters - 2009
Fri, May 23, 2008 at 6:10:24 AM | Area and parking parameters - 2009
tim123
4 Stars: 19 Votes
I'm trying to create a schedule that includes parameters from two diffrent sources.  I have a parking schedule and need to include the parameter from the area schedule so that I can show the number of parkings as a ratio of the gross building area.  Any help on this matter would be appreciated.
Tue, Nov 11, 2008 at 1:49:20 PM | Area and parking parameters - 2009
JHPBCJ
I am trying to do this as well, though I am doing mine for a mixed use development that has different ratios depending on building use.
If everything is the same it's actually pretty simple -  In Schedule Properties you make a new Calculated Value whose formula is "Gross Floor Area / XX SF"  where XX= the ratio of SF to parking space.
My problem is in mixed use I can't figure out how to make a different formula for each different building type without splitting the schedule up.  I think I might end up in Excel.
Creating Recessed Parking Area
Sat, Aug 9, 2008 at 7:39:24 AM
area schedules
Sun, Jun 17, 2007 at 2:31:25 AM
area schedues
Tue, May 15, 2007 at 7:34:36 PM
Parking Visibility
Tue, Nov 27, 2012 at 8:53:22 PM
Area plan wont show color
Thu, Oct 2, 2014 at 3:19:35 PM
Page generation time: 1.4287
