Forums >> Revit Systems >> Technical Support >> Load analysis problem in MEP 2009
Thu, May 22, 2008 at 10:46:01 AM | Load analysis problem in MEP 2009
jfmonod
 Hi.
 Tutorials, help files, all info on-line say: "The calculated values from the heating and cooling load analysis are automatically applied to the properties for the spaces in your project."
 My problem is that they're not. All fields that should fill in after running load calcs are still saying "not computed"...
I have a linked project, I have spaces over rooms, I have spaces not over rooms, I have a location, I have lights, I have diffusers... But the only numbers I have are in the loads report. Nothing is showing up in my space parameters or in my space schedule....
 help ?
 Many thanks.
 JF
Wed, Jun 25, 2008 at 11:45:46 AM | Load analysis problem in MEP 2009
DESIGN4BUILDING
DESIGN4BUILDING Avatar
3.5 Stars: 3 Votes
are you talking about you schedule, under volume states not computed ??
Browser organization for Spaces for Energy Analysis, MEP
Sat, Mar 9, 2013 at 12:50:04 PM
Entering or linking to envelope U-values
Mon, Mar 30, 2009 at 1:22:23 PM
Revit Structure to MEP
Tue, Feb 24, 2009 at 7:19:48 AM
Unable to start robot analysis structure (HELP NEEDED)
Tue, Apr 29, 2014 at 10:11:09 AM
Revit MEP 2009
Mon, Mar 9, 2009 at 12:24:19 PM
Page generation time: 0.7588
