Forums >> Revit Building >> Technical Support >> matching prop.
Thu, Jan 15, 2004 at 2:32:16 PM | matching prop.
Bimman
Bimman Avatar
1 Stars: 2 Votes
hj, is there a tool that matches the prop of say a wall including heights or just does the match type just do type of the wall not indvidual props mainly heights. rather thatn having to input them one at a time.
PWD
Thu, Jan 15, 2004 at 6:05:31 PM | RE: matching prop.
Priority
Match properties (eye drop icon) will only change family or type parameters. When you want to match properties of multiple objects and you want to include instance parameter such as wall height. 1. Hold down the control key and select all the elements you want to change. 2. When they're all highlighted right click and go into the element properties dialog box and change all the parameters.
Fri, Jan 16, 2004 at 7:40:21 AM | RE: matching prop.
Bimman
Bimman Avatar
1 Stars: 2 Votes
tha tis what i have been doing. i was just trying to see if there was a faster way, as if revit wasn't fast enough.
PWD
Material color matching
Wed, Apr 9, 2014 at 9:22:08 AM
Elevation Levels are not matching with Project browser.
Fri, Feb 10, 2017 at 5:06:55 AM
Prop Aeroplane/Vehicle
Sat, Apr 16, 2016 at 2:33:25 PM
Matching paint samples with Revit Renderings
Tue, Jun 28, 2016 at 4:23:03 PM
Matching Room Numbers in Area's and Room Tag
Thu, Jun 12, 2014 at 10:12:08 AM
Page generation time: 0.0240
