17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> I can't get the horizontal portion of a lean-to frame to display in Plan Views.
4 Posts No Rating |
Hello, I would much appreciate some light anyone might be able to shed on this issue. I using RAC 2008. I have imported a .rfa lean-to frame into my project which displays fully in 3d and in elevation. I cannot get the horizontal portion to display regardless of my cut plane and view range. Any suggestions? Thanks for considering JBrent
Check your section box, Far Clip and Far Clip Distance? I can't seem to open your files. Can you attach screenshots, instead?
In the .rfa file, select the model's sweep in plan view (ref level) and then click on the visibility button. Currently plan view is unselected, which is why it is not showing in your plan views. Many families are like this, so it pays to check the visibility if it does not display as expected.
Deb |
4 Posts No Rating |
Deboddy, Thanks for the education. As you know your instructions were dead on, easy to follow, and gave me one more bit of understanding of families. Thank you JBrent
Grids at an Angle in Plan don't display in Elevation |
Thu, Apr 26, 2012 at 2:44:38 PM
display of families in different views |
Mon, Oct 19, 2009 at 9:15:23 AM
11
How Do I Create A Lean To Roof Over A Garage |
Thu, Jan 15, 2009 at 3:31:31 PM
11
HELP! ALL of my plan views vanished!!!! I've tried creating new views |
Wed, May 9, 2018 at 3:18:43 PM
Displaying 2X6 wood frame walls in floor plan |
Tue, Feb 6, 2007 at 10:00:52 AM
