Forums >> Revit Building >> Technical Support >> Symbols in Schedules
Wed, May 21, 2008 at 1:35:34 PM | Symbols in Schedules
SteveFrancis
I am using RAC09, Is there a way to add an image or symbol into a schedule.  We use a large dot symbol in the column under the header on our room schedule and I have not yet figured out how to get it to work in REVIT.  Any ideas?
Thanks
Wed, May 21, 2008 at 4:24:15 PM | Symbols in Schedules
If you make a yes/no field, you get a check box..... I know - it doesn't look the same as the dots we used to use but visually it works.  You might want to register the option to change this in the AUGI wish-list area.
Fri, May 23, 2008 at 11:40:01 AM | Symbols in Schedules
SteveFrancis
Thanks for  the info.  I will put that on the wish list.
Annotation symbols and schedules.
Wed, Aug 13, 2014 at 3:48:34 PM
Deleting import symbols
Thu, May 8, 2008 at 3:14:21 PM
symbols, detail components
Mon, Jan 23, 2012 at 6:35:40 AM
SYMBOLS
Fri, Mar 6, 2009 at 11:02:48 AM
Electrical symbols - scaling
Tue, Feb 5, 2013 at 7:18:56 AM
Page generation time: 0.2733
