Forums >> Revit Building >> Technical Support >> Ramp railing
Wed, May 21, 2008 at 6:02:31 AM | Ramp railing
Dafpfy
3.5 Stars: 11 Votes
is it possible to attach a railing to a ramp after having deleted the automaticaly created railing when the ramp is first created?
Kind regards
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Wed, May 21, 2008 at 6:06:10 AM | Ramp railing
4 Stars: 205 Votes
Hi, yes it's possible, go to rails and after, pick in "HOST" and select the ramp....
Wed, May 21, 2008 at 7:34:27 AM | Ramp railing
Dafpfy
3.5 Stars: 11 Votes
tnx,
sometimes a railing on a ramp is taking a dive to the base level and some meters later jumps back up, or just doesnt follow the slope of the ramp.
ever seen this? and what can i do about it, ?
peace is the path."
Mahatma Gandhi.
Wed, May 21, 2008 at 9:07:09 AM | Ramp railing
4 Stars: 205 Votes
Yeah, sometimes the rails had this "madness", in ramp or stairs, but if you choose "HOST" and select the obj. "He" respect the slope...
Thu, May 22, 2008 at 2:34:52 AM | Ramp railing
Dafpfy
3.5 Stars: 11 Votes
nope doesnt always work correctly.
Would appreciate somebody taking a quick look at it,
tnx!!
peace is the path."
Mahatma Gandhi.
Thu, May 22, 2008 at 4:08:47 AM | Ramp railing
4 Stars: 205 Votes
Hi "Daf", i see your file and now you can see that's correct, when the rail is "broke" (turn other direction) it's when revit begin "confusion", the best way is edit this rail, delete the segment was wrong, close, then create another segment by "Host"....
Flat Railing with a ramp as a host
Mon, Dec 27, 2010 at 6:27:11 PM
Offset Railing Height
Sun, Feb 1, 2009 at 4:47:25 AM
wall railing for ramp
Wed, Dec 18, 2013 at 1:52:55 PM
stair and ramp railing
Sat, Sep 9, 2006 at 3:41:33 PM
Stair-ramp-landing Problem
Mon, Mar 24, 2014 at 11:13:25 AM
Page generation time: 0.9370
