Forums >> Revit Building >> Technical Support >> Perspective
Wed, May 21, 2008 at 5:13:00 AM | Perspective
CntrlAltDel
Hello
Could anyone explain what's going on in the first rendered view.. I've made a perspective view with a camera, though all windows seem to be stretched insanely.. I've used a second camera view and deselected perspective in it and that image shows how it should look like..  What's the use of a perspective image when everything seems to be messed up.
Wed, May 21, 2008 at 5:52:10 AM | Perspective
4 Stars: 205 Votes
Hi, i never use 3d perspective to made my renders, i just use camera views, i don't remember what version ( revit 9 or 200Shadey when i render a 3d-view it takes to much time to do it but when switch to Camera view it's faster, so now i always use "Camera Vies" to my renders NEVER - 3D VIEW...
Wed, May 21, 2008 at 6:17:33 AM | Perspective
CntrlAltDel
I know what you are talking about as I've tried to render a rd-view aswell in the past, though I'm talkin about something else.. WHen you open the view section and click on the camera button, you can see a small check box just above your view.. Deselecting this give you the option to make a non perspective view ( whatever that isSmile)..Using this methode makes pictures with good proportions, though It's a tad more work to get everything on the right angle and stuff and I've always used the first methode and never really experienced problems with this untill now..
Wed, May 21, 2008 at 6:20:57 AM | Perspective
CntrlAltDel
Perspective Problem
Fri, Jun 26, 2009 at 12:13:43 PM
Wishlist - Default perspective 3d view
Fri, May 2, 2014 at 9:31:09 AM
Moving Objects in 3d Perspective View
Wed, Jul 27, 2016 at 3:52:14 PM
perspective view
Thu, Feb 7, 2013 at 1:47:34 PM
Deleting Perspective When Rendering
Wed, Nov 30, 2011 at 1:08:18 PM
Page generation time: 0.0351
