Forums >> Revit Building >> Technical Support >> Not vissible
Tue, May 20, 2008 at 5:28:37 AM | Not vissible
CntrlAltDel
Hello
I've tried to render several plants, though for some reason their only vissible in the normal (not rendered) mode..
Does any one have a clue about what setting needs to be changed. I don't really have any idea where to look for..
Thanks
Tue, May 20, 2008 at 5:43:18 AM | Not vissible
4 Stars: 205 Votes
Hi, i think you must be more specific about your question, what version of Revit do you work? what plants do you insert? settings of render (draft, best...), put some image from render to see what it's hapen...
Tue, May 20, 2008 at 6:00:21 AM | Not vissible
CntrlAltDel
Hello Typhoon
I'm working with the newest version Revit Architecture 2009...I have it with most plants and to give yuo an idea of the situation, I will add 2 pictures of a tutorial drawing.  The settings of the render where "draft", Lighting--> exterior sun only..
Hope that's enough info...
Tue, May 20, 2008 at 6:24:10 AM | Not vissible
4 Stars: 205 Votes
Right now i don't have here Revit 2009 but i think this tree it's from 2008, try insert a tree by RPC component, there are M-RPC...(male, female, shrubs, trees...), there are a folder in revit 2009 with RPC, then you can change your tree with properties, name, heigh, type and so one. When i open an old project in Revit 2009 the trees in that model appears just like your model in 3d-view but when i do  the render thei dissapears so... try to do this.
Send me a feedback..
Good luck
Tue, May 20, 2008 at 6:40:31 AM | Not vissible
CntrlAltDel
Yes finally it worked...thanks a lot...
I always used the simplistic plant familie from the library, though never used the RPC component. This looks so much better..
Door family elements showing in plans
Sun, May 1, 2011 at 9:29:23 PM
Two different detail items in sections
Wed, Apr 5, 2017 at 12:11:03 PM
Door and Window Scheduling - showing the door and window as an image.
Thu, Feb 11, 2016 at 12:17:42 AM
revit 2013 exterior walls not showing correct
Wed, Jun 12, 2013 at 2:34:03 PM
invisible road carparks and landscape on site plan
Thu, Aug 27, 2009 at 3:08:57 PM
Page generation time: 3.0916
