Forums >> Revit Building >> Technical Support >> Walkthrough won't playback, what codecs are required?
Mon, May 19, 2008 at 10:14:25 AM | Walkthrough won't playback, what codecs are required?
grebiwnotnerb
3.5 Stars: 12 Votes
When I export a walkthrough as an AVI file and then try to watch it, media player gives me this error: "Windows Media Player cannot play the file. One or more codecs required to play the file could not be found."  What codecs do I need and where can i find them?  I've tried using DivX player, but it gives me a similar message.   The confusing thing about this all is that if I interrupt the exporting process before about 50% of the walkthrough is rendered, then the file will play back, but if it gets much further than that, the above mentioned error comes up. Any suggestions, tips etc.
Tue, May 20, 2008 at 10:10:05 AM | Walkthrough won't playback, what codecs are required?
rkitect
rkitect Avatar
4 Stars: 29 Votes
Try installing and using The Core Media Player or VLC Player.  If neither of those can play it then you need to break it down into smaller chunks.
Rendered Walkthrough
Thu, Jun 7, 2007 at 7:39:51 AM
walkthrough rendering frame counter?
Thu, Aug 20, 2009 at 10:50:49 AM
Walkthrough playback error
Tue, Feb 24, 2009 at 6:38:10 AM
walkthrough questions
Mon, Mar 25, 2013 at 2:44:09 PM
Rendered walkthrough is blurry
Tue, Dec 2, 2014 at 1:41:44 PM
Page generation time: 2.4582
