Forums >> Community >> Newbies >> New to Revit, converting from CAD questions
Mon, May 19, 2008 at 9:25:20 AM | New to Revit, converting from CAD questions
V1ad
Hi,
The project I am working on has a fully developed AutoCAD Architectural Desktop 3-D model.  Is there anyway to reuse the 3D elements in Revit, or do I have to remodel everything to make them Revit objects?  Example: all the structure is 3-D modeled, beams/columns, etc., it would be nice if I could just import the 3-D geometry and turn it into a coulum and a beam objects in Revit.
 Any suggestions would be greatly appreciated.
Thanks
Mon, May 19, 2008 at 9:38:54 AM | New to Revit, converting from CAD questions
4 Stars: 205 Votes
In these cases use in Autocad Architectural Desktop exportation with IFC, and import in Revit By IFC format, in this way, Revit assume the objects and materials you made in Autocad.
Mon, May 19, 2008 at 4:28:16 PM | Typhoon
V1ad
Quoting Typhoon from 2008-05-19 09:38:54
"In these cases use in Autocad Architectural Desktop exportation with IFC, and import in Revit By IFC format, in this way, Revit assume the objects and materials you made in Autocad."
OK, please bear with me, as I am in baby step mode.  I exported the structure out of CAD as an .ifc.  Then I imported it into Revit.  Some of the columns (the really simple square concrete ones)  becasme recognized as columns and are listed in the pull down menu.  However, the one's I really needed to be converted, which are I-beams that are all on  different angles, don't seemed to be recognized.  They are there, but they are grayed out.  I can select them, and that's about it.  What would be my next step to convert those into Revit columns?  I am going to take a look at how they were constructed in CAD, maybe that has something to do with it.
Thanks a lot for the suggestion.  I feel like I am making some progress.  Thanks Again
-V
Tue, May 20, 2008 at 4:03:46 AM | New to Revit, converting from CAD questions
4 Stars: 205 Votes
Hi "V1ad", is "I-beams" in your file CAD a Block? take a look, i remember when i work with Autocad Architectural i insert this I-beams from the "Catalog" witch have diferents dimensions, so i think there are a Block, explode them and try again....
Good luck
Wed, May 21, 2008 at 3:25:05 PM | New to Revit, converting from CAD questions
V1ad
Hey,
It seems exploding the colum in CAD makes it even less recognizable in Revit.  If I don't explode it in CAD some the information does get brought into Revit.  In CAD the different kinds of columns are identical except for their geometry.  THey seem to have been made the same way.  I tried exporting one colum at a time, but still the same problem.
Wed, May 21, 2008 at 4:33:36 PM | New to Revit, converting from CAD questions
NKramer
4 Stars: 9 Votes
V1ad
This may create more work than it saves but you could try taking all of the complex columns, changing them to something simple, export to ifc, import in revit, select all insances and then change back to the complex form.
HTH
Nick
Thu, May 22, 2008 at 8:44:07 AM | New to Revit, converting from CAD questions
V1ad
OK, I think this is getting to the root of my question.  Is there anyway to use existing geometry in the process of making a Revit colum?
Thu, May 22, 2008 at 9:24:33 AM | New to Revit, converting from CAD questions
NKramer
4 Stars: 9 Votes
Not that I know if. You would have to draw a new beam which you may then be able align to something in the existing model. It depends how the import comes in. Generally you have access to the linework in AutoCAD imports but sketchup and others you dont.
Let us know what you find out.
Nick
Fri, May 23, 2008 at 9:28:05 AM | New to Revit, converting from CAD questions
V1ad
Is there a way of converting a AutoCAD 3D object into a mass in Revit?
Thu, Apr 28, 2011 at 10:22:40 PM | New to Revit, converting from CAD questions
NAMECIB7610
Hi V1ad,
Yes you can convert to a mesh.  See the post I just posted an that very topic.
Hope that helps,
NAMECIB7610
Converting DWG materials to Revit Materials
Thu, Sep 13, 2012 at 3:50:29 AM
converting files for use between cad programs
Thu, Apr 30, 2009 at 12:39:03 AM
New To Revit
Wed, May 14, 2008 at 9:39:20 AM
import cad
Thu, Dec 8, 2016 at 5:06:17 PM
Revit Family & Cad Dwg
Fri, May 13, 2011 at 7:18:00 PM
Page generation time: 1.3783
