11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Can I use images with alpha channel?
3 Posts No Rating |
Hello everyone! I am using Rvit architecture 2008, and I´m trying to make a sheet to be a resume of my project, so I´m including some photo references...The problem is that I would like to crop the images; could someone, please tell me if it is possible to use some kind of alpha with the images or if there is some way to crop them? Thank you in advance
Use PHOTOSHOP... i think it's the best way...
3 Posts No Rating |
Thank you Typhoon, I did it in Photoshop, but I still have a problem, and it is that I would also like the images to be transparent in some areas, so that I could, for example, use the image of a tree and see anly the tree, and not the background of the .jpg image or so. Do you know any way to do that? Thank you!!!
Hi, with PTSHOP CS2 or CS3 you can create a mask and "crop" then save with other name to preserve the original, then with the Crop image you can put them transparent and so one...
3 Posts No Rating |
Thank you!!!
Export to dwf alpha channel |
Mon, Feb 13, 2012 at 4:08:16 AM
Alpha Channel? |
Tue, Aug 28, 2007 at 3:41:17 PM
Revit 2008 & exporting alpha chennels |
Wed, Sep 5, 2007 at 2:28:18 PM
Rendering with no sky. |
Sat, Mar 21, 2009 at 7:57:10 AM
Revit 2010 to 3ds Max Design 2010 |
Mon, Aug 10, 2009 at 4:46:18 PM
