Forums >> Revit Building >> Technical Support >> Makeing Precast Panels
Fri, May 16, 2008 at 10:52:16 AM | Makeing Precast Panels
jwilsmann
Could someone please explain to make an exterior wall look like precast panels or give me a link to a walkthrough or tutorial?  I've been trying to make one using a curtain wall.  I can get the panel sizes to appear, but can't figure out how to make the panels have a precast material.  Any help would be greatly appreciated.
Fri, May 16, 2008 at 12:15:53 PM | Makeing Precast Panels
JHanby
3.5 Stars: 3 Votes
Go to your families and under Curtain Panels, pick the panel that you are using and go to properites.  You can change the panel material to precast concrete panel.  HTH
Mon, Aug 17, 2009 at 7:26:12 AM | Makeing Precast Panels
Vidaman
I make concrete homes with individual panels and the disjoin command is the ultimate command.  I use a shared parameter as well to help schedule the wall panels.  Though on my drawings I only need to show the concrete, I find it difficult to add more materials to the wall like insulation or brick and still get a nice wrapping on the corners, So I usually make a working drawing and a Render drawing.
Mon, Aug 17, 2009 at 7:35:05 AM | Makeing Precast Panels
I don't understand why you are not using walls.  Is the insulation and interior finsih added to the precast panels or part of it?  I have also used walls for precast panels and used void vertical sweeps to cut the walls into panels.
Precast Concrete Panels
Fri, Mar 31, 2017 at 12:28:39 PM
13
Placing window at intersection of 2 precast concrete panels
Sat, Jan 5, 2008 at 7:57:00 AM
Precast insulated wall panels
Wed, Oct 18, 2017 at 10:45:29 AM
Precast Panels
Mon, Jan 7, 2008 at 3:39:27 PM
Precast panels and vertical reveals
Thu, Jan 17, 2013 at 9:38:52 AM
Page generation time: 3.2427
