Forums >> Revit Building >> Technical Support >> Structural framing not visible in plan
Fri, May 16, 2008 at 9:52:31 AM | Structural framing not visible in plan
Rams
3 Stars: 3 Votes
I have linked a structural model into my architectural project. I can see structural column & bracing but beams are not visible in plans. I have tried all the possibilities thru visibility graphics and view range.
Please give me some suggestions
Now on the implementation stage....
Fri, May 16, 2008 at 1:06:54 PM | Structural framing not visible in plan
lunchtrayrider
3.5 Stars: 7 Votes
Your beam family might not be set to show on a course detail level.  It also might have its visibility set to not show in plan/rcp.  I would check these.
Mon, May 19, 2008 at 5:15:46 AM | Structural framing not visible in plan
Rams
3 Stars: 3 Votes
Both options seems to be correct. Any other suggestions please
Mon, May 19, 2008 at 5:59:27 AM | Structural framing not visible in plan
4 Stars: 205 Votes
It must be in the View Range, (I.E.: if your beams are 4 meters from the ground put Top and Cut plane to 5 meters), if you create the beams with mass element go to VP and in model check if "Mass" is visible...
Tue, May 20, 2008 at 4:56:35 AM | Structural framing not visible in plan
Rams
3 Stars: 3 Votes
Nope. Its not working.
truss not visible on framing plan
Mon, Apr 27, 2009 at 4:28:30 PM
Structural framing plan for a sloped roof?
Fri, Mar 29, 2013 at 9:53:50 AM
Structural Framing Plans/Callout Beam Sizes
Wed, Feb 22, 2006 at 5:49:10 PM
Structural Framing Tag
Tue, Feb 26, 2008 at 10:27:24 AM
Framing Plan
Tue, Jan 3, 2006 at 4:10:28 PM
12
Page generation time: 1.0297
